4.0 ZJ turns over but won't start - JeepForum.com
post #1 of 81 Old 08-31-2013, 12:14 AM Thread Starter
JBrady5555
Ok fellas about a week ago I went to start my 97 ZJ and all I got was a click from the starter, I checked the battery terminals and spotted a little bit of corrosion so I wiggled the cables and it fired right up the next time I cranked it. It did fine for a week never showing signs of the problem but today it did it again once I got home from running a few errands. This time when I checked the terminals I noticed that they were clean but the wire ends were in bad shape, so I left the terminals hooked to the battery and I loosened and removed the wires from the terminals and cleaned them. As I put the wires back into their respective terminals I could hear and see a little cracking and sparking as I tightend them back down. No doubt this is not the correct way to do this job, I'm still racking my own brain on why I didn't just pull the whole terminal before I removed the wire ends.
Well after I got everything hooked back up I went to see if the truck would turn over. As soon as I hit the key it was turning over awesome, I managed to fix the terminal connection issue. One big problem though......Now it turns over but WON'T START!! I couldn't believe it since its never gave any issue other than the occasional click without turning over. The first thing I noticed was that when I turned the key on I can't hear the fuel pump anymore, even from crawling under the back of the truck. Coincidence that the fuel pump would go out at the same time that I removed the battery terminals? Seems doubtful to me. So I went to the black fuse box by the battery and swapped the fuel pump relay with the two of the other relays, both times I tried it didn't help. Also the other fuses look fine.
This started to lead me to think that the unlikely coincidence of the fuel pump going out at the same time that I was doing the battery work may be a possibility. This was until I jumped onto jeep forum and researched my problem. It seems that unhooking the battery has caused many folks on here to get a lot of weird problems like needing new sensors or fouling up the security system. After researching I did try to key the back hatch and the drivers door in case I had a security issue, this didn't help me. I also tried the key "on, off, on, off, on" thing to pull any engine codes. I couldn't get it to read anything.
Another piece of info that my be useful in figuring out my problem is that when I turn the key to on and the dash lights come on, all the gauges stay on zero. I figured that at least the volt meter would come up to 12, or that the fuel gauge would read the half a tank or so of fuel thats in the ZJ now. It all just doesn't move and the fuel light is actually on but I'm guessing that its just on because the gauge hasn't lifted off of the needle right? I'm positive that its not out of fuel. Well from the info I've given here does anyone know what kind of problem I might be looking at? Thanks for any info.
JBrady5555 is offline
post #2 of 81 Old 08-31-2013, 12:35 AM
wranglinman87yj
It sounds like a blown fuze/relay...
wranglinman87yj is offline
post #3 of 81 Old 08-31-2013, 01:15 AM
Speedymcracer01
First of all when you turn the key over does the check engine light come on then go back off like it should
Speedymcracer01 is offline
post #4 of 81 Old 08-31-2013, 01:35 AM
Oldfrog
2007 WK
Check the ASD fuse under the hood.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #5 of 81 Old 08-31-2013, 06:21 AM Thread Starter
JBrady5555
No it doesn't come on
post #6 of 81 Old 08-31-2013, 06:24 AM
Kingr98
2016 JK Wrangler
What Oldfrog said. Swap tne ASD relay with another one, but not the fuel pump relay.
Automatic Shutdow Relay is what allows the fuel pump to get that initial two second prime.
Kingr98 is offline
post #7 of 81 Old 08-31-2013, 06:42 AM
Speedymcracer01
Well if no check engine light comes on at all not even when you turn the key over then thats your computer mine did the same thing it was a blown fuse in the pdc it was a small fuse that wasn't marked i had to take the pdc out and get the fuse number off the bottom then look it up in the wiring diagram.A loose o2 sensor rubbed on my drive shaft and arked which blew the fuse to the computer. I would double check the fuses in the pcm to make sure
post #8 of 81 Old 08-31-2013, 06:51 AM Thread Starter
JBrady5555
Ok i just swapped the asd relay with several others and it didn't do anything different. Also I pushed in on the fuel rail bleeder valve and it was empty. It barely hissed as I pressed it, no fuel came out at all.
post #9 of 81 Old 08-31-2013, 06:53 AM Thread Starter
JBrady5555
Makes sense, I probably fouled it up when I pulled the battery wires somehow. Where exactly is the pdc? Isn't that the black box with all the relays and fuses?
post #10 of 81 Old 08-31-2013, 06:59 AM Thread Starter
JBrady5555
I checked all the little fuses too by the relays but they all look good.
post #11 of 81 Old 08-31-2013, 07:00 AM
Speedymcracer01
The only other thing that i think it could be is the crank shaft position sensor it is known to cause these types of issues
post #12 of 81 Old 08-31-2013, 07:03 AM
Speedymcracer01
Yes the pdc"power distribution center" is the black box by the battery
post #13 of 81 Old 08-31-2013, 07:04 AM Thread Starter
JBrady5555
Is it likely that it would fail because of the battery connection issues that I was having? I imagine that it's a cheap part, is it easy to change out? It couldn't hurt to try if it's a easy job to do.
post #14 of 81 Old 08-31-2013, 07:05 AM
JS97ZJ
It's fuse 20, a 20 amp fuse
JS97ZJ is offline
post #15 of 81 Old 08-31-2013, 07:06 AM Thread Starter
JBrady5555
Ok, why did you have to remove the box if you had a fuse problem? Couldn't you access all the fuses with the box in place?
