4.0 ZJ Stalling/Losing power after long drives? - JeepForum.com
post #1 of 5 Old 08-25-2013, 04:16 PM Thread Starter
reydelaplaya
Hey folks! Hope y'all's summertime has been full of fun!
Just hoping to find some ideas as to why my 96 4.0 has been trying to stall after longer drives.
My usual commute is about 1/2 an hour or so, but recently I had to go to the other side of the island to pick up a friend at the airport - a highway drive about 2hrs or so one way. As I was coming back, about an hour and a half into the trip, when I stepped on the gas, the engine attempted to die out a couple times. I was in an area where I could pull off the highway, and did so, in order to give it a rest. After a rest of about 30min or so, it drove perfectly for the duration of the trip.
The next day and the day following, it did the same after running almost an hour for both to and from a trip to the south of the island - about an hour's drive one way.
Instinct and experience tell me it's probably a clogging cat, but there's no CEL, and it's fine after a quick rest.
Most recent tune up was less than 2 yrs ago. Plugs/wires/rotor/cap/air filter/fuel filter/etc. were all changed, have been checked, and are all in great condition.
For my local drives, including my drive to and from work it's fine, with no loss of power whatsoever.
Temp's normal, oil pressure and voltage, too. Nothing to suggest a problem.
You guys got any ideas?
Thanks,
Rey
reydelaplaya is offline
post #2 of 5 Old 08-25-2013, 06:39 PM
ZeeJay1997
the bogging down when you step on it may be a clogged cat. if the engine temp rises slightly when this occurs, it's even more suspect. do the key trick and check for stored codes. some codes may not turn the light on, including misfire codes.
Your coil is also suspect. take it out and check for cracks and arcing.
ZeeJay1997 is offline
post #3 of 5 Old 08-25-2013, 10:28 PM Thread Starter
reydelaplaya
Thank you for the tips! I'll start there when I get home from work tomorrow and see where it leads me.
Thanks again!
I'll post results when I have 'em.
post #4 of 5 Old 02-10-2016, 03:54 PM
radioguy97
Hi Guys, I know this is an old post but ive developed the same issue. After driving an hour or more the engine will not rev over 2000 and has low power.
I have replaced plugs, cap, rotor and wires as well as removed the cat and new muffler and air filter.
Any additional thoughts?
Thanks in advance
radioguy97 is offline
post #5 of 5 Old 02-10-2016, 05:39 PM
Virmagicus
Virmagicus's Avatar
What year and make radioguy?
Jeff
Virmagicus is offline
