4.0 ZJ intermittent stumble in idle - JeepForum.com
post #1 of 7 Old 08-24-2013, 12:12 AM Thread Starter
JaneLee
1994 ZJ
funky issue and no solutions in sight. i have a 94 4.0 I6. it has an intermittent slight stumble in P or N but RPM is normal. As soon as you put it in any gear the RPM drops to about 5-600, stumbles and acts like it wants to die. Cleaned the throttle body and butterfly, replaced the TPS, MAP sensor and IAC. No vacuum leaks, all injectors working with no leaks there, fuel pressure is normal at 33psi. No change in running with or without O2 screwed in so i don't think it's the CAT and CAT has no rattle at all. It wont make to a shop so i can get it scanned. Any suggestions?
JaneLee is offline
post #2 of 7 Old 08-24-2013, 07:17 AM
newfieZJ
Start by cleaning your grounds .
Re-seat all your fuses and relays everywhere , and your PCM connection . Clean as needed .
Clean battery terminals
Consider pulling the crank sensor and cleaning it . It's a magnetic pick up and it picks up small metallic debris . Could be a weak signal .
If your check engine light(CEL) is on , use the key method to retrieve codes . Key to on(not start) off , on , off , on . Then the codes will blink via the CEL by blinking . Blink blink blink space blink blink = code 32
Try this first , it's free . If no luck , post results .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 7 Old 08-24-2013, 10:28 AM Thread Starter
JaneLee
1994 ZJ
throws no codes, just start and stop 12-55. battery term clean. pcm?
JaneLee is offline
post #4 of 7 Old 08-24-2013, 02:20 PM
Oldfrog
2007 WK
Merely unscrewing the o2 sensor will not give you the desired results for a test. Disconnect it from the connector.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #5 of 7 Old 08-24-2013, 03:07 PM
ZeeJay1997
good catch oldfrog. aren't we fixing the same jeep in another thread?
ZeeJay1997 is offline
post #6 of 7 Old 08-24-2013, 03:22 PM Thread Starter
JaneLee
1994 ZJ
probably lol had internet/puter issues. mine went down and had to borrow being i'm stranded in another state
JaneLee is offline
post #7 of 7 Old 08-24-2013, 03:25 PM
ZeeJay1997
disconnect o2 sensor. the connector should be under the manifolds
