-   -   4.0 tear down w/pics and questions (http://www.jeepforum.com/forum/f13/4-0-tear-down-w-pics-questions-1542583/)
JBrady5555 06-28-2013 06:55 PM
Well I started my freeze plug tear down today. The parts wont be in until tomorrow but I figured I would get ahead of the game. Everything went smooth considering I've never took a engine down this far before. The bottom intake manifold bolts were the hardest for me, they are hard to get to and you have to do the job blind for the most part. Here are a few pics and some questions I got along the way.
http://cdn.homebrewtalk.com/images/9...40-1-60354.jpg
Here is one of the worst leaking freeze plugs. I have two that are this bad.
JBrady5555 06-28-2013 06:56 PM
Here is what the back two freeze plugs look like. Why are they different? Do all 4.0 use washers for the back two plugs.
http://cdn.homebrewtalk.com/images/9...43-1-60355.jpg
JBrady5555 06-28-2013 06:57 PM
Here is a pic of the back drivers side corner of the valve cover, pretty bad oil leak. Glad I got a new gasket.
http://cdn.homebrewtalk.com/images/9...42-1-60356.jpg
JBrady5555 06-28-2013 06:59 PM
Thats as far as I have gotten, I didn't get the exhaust manifold off because weather set in. I pluged the intake ports with rags to keep moisture and whatever out, is it nessecary to do this? Should I try to clean all the gunk out of the inside of the intake manifold, what can I use to get the grime out. Since its tore down this far I wouldn't mind getting everything cleaned up. Not show truck nice but at least clean.
jm8881 06-28-2013 07:07 PM
I believe the back freeze plugs have been replaced with universal freeze plugs. I never liked those. They are just a rubber disc sandwiched between two washers with a nut you tighten down.
JBrady5555 06-28-2013 07:12 PM
So can I just replace these with the new oem style plugs that I have ordered?
ZeeJay1997 06-28-2013 07:24 PM
I had good luck cleaning the intake using a drain pan, engine cleaner (The gallon jugs you get at the parts store), and a plastic bottle brush. Stood the manifold up and soaked it all with cleaner, let it sit. Then soaked the brush and pushed it through ports to scrub. Washed it out with water hose while still scrubbing and it looked almost new afterwards.
The bottom manifold bolts are tough to get started. Be double sure they don't cross thread. I had an extension and deep socket just long enough to reach beyond the edge of the manifold, so it was off to the races tightening them up.
Seems like I had to take a fuel line bracket off for clearance.
Be sure to use a torque wrench.
Yes, use the OEM freeze plugs to replace the universal ones.
JBrady5555 06-28-2013 07:28 PM
Should either the valve cover gasket or the intake/exhaust manifold gasket get rtv? I know there is mixed feelings on the valve cover gasket but what about the other?
um7267 06-28-2013 07:46 PM
i guess some people do from what i have read on here but i would just buy the gasket from autozone or where ever you get parts from
ZeeJay1997 06-28-2013 07:48 PM
NO RTV!
Use tack glue on the bottom of the valve cover gasket and tack to the head, then install the cover.
If you are getting a Felpro manifold gasket you dont need copper seal. Some people swear by it, but i didnt use it and it is fine.
JBrady5555 06-28-2013 07:56 PM
Originally Posted by ZeeJay1997 (Post 15619581)
NO RTV!
I did get the felpro gasket w/grommets. What exactly is tack glue and where can I buy it? I haven't removed the valve cover yetand have never done one on a 4.0 before.. From what your saying is that I need to mate the new valve cover gasket to the head w/ the tack glue and then set the valve cover on top correct?
coralman 06-28-2013 08:01 PM
If you get the correct valve cover gasket it will have a steel core with a rubber exterior with ridges, no need for RTV. However, the valve cover may have been bent or warped over the years so lay a straight edge against the sealing surfaces and see if they are in fact inline and flat. If not you may have to take a block of wood and lightly reshape them back into line.
This thread by Uniblurb and around post #39 by ZeeJay, may give you insight into the manifold removal and replace.
http://www.jeepforum.com/forum/f13/e...02/index3.html
ZeeJay1997 06-28-2013 08:03 PM
yes, here's what you need.
JBrady5555 06-28-2013 08:08 PM
Originally Posted by ZeeJay1997 (Post 15619620)
Awesome I'll pick some up in the morning when I go to pick up my parts. How much do you use? Around the entire thing or do you just use a few spots of the glue in certain areas around the gasket?
ZeeJay1997 06-28-2013 08:10 PM
just a light coat all way around.
The time now is 11:31 AM.
