4.0 tapping matching rpms - JeepForum.com
post #1 of 25 Old 05-06-2012, 10:31 AM Thread Starter
sevenscrew
there's a tapping sound from near the center of the intake manifold /engine. has a bad valve cover gasket leak. 196k
it matches the rpms and is more noticable since I put in a new muffler and tailpipe.
any ideas ?
1997 Limited 5.2L - SOLD
2016 2DR JK
sevenscrew is offline
post #2 of 25 Old 05-06-2012, 10:57 AM
dusterdude
Lifter?
dusterdude is offline
post #3 of 25 Old 05-06-2012, 11:13 AM Thread Starter
sevenscrew
can I easily access/fix a lifter with the cover off
2016 2DR JK
post #4 of 25 Old 05-06-2012, 11:20 AM Thread Starter
sevenscrew
2016 2DR JK
post #5 of 25 Old 05-06-2012, 11:23 AM
JasonStebbins
Sounds maybe like a lifter, is the oil up to level? Could be a cracked manifold as well.
Yes. There are like 12-14 bolts that hold the cover on. The hardest part is getting around all the throttle/transmission cables.
I would recommend changing the front and rear PCV valves while you have the cover off.
Poop
JasonStebbins is offline
post #6 of 25 Old 05-06-2012, 01:40 PM Thread Starter
sevenscrew
oil needed 4 quarts when we picked it up for 450 bucks. so it was almost empty for idk how long probably arounda month. Once i get the cover off, if its a lifter, can i change it with just a torque wrench? and is the part a dealer item then?
2016 2DR JK
post #7 of 25 Old 05-06-2012, 02:53 PM
Oldfrog
2007 WK
Before you begin tearing it down, try pouring a little marvel mystery oil in the crankcase. Drive it for a day, then change the oil again. See if it stops.
That said......sometimes even a brand new 4.0 will sound a bit like a diesel engine at times. Both of mine have, every once in a while and I bought them both new.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #8 of 25 Old 05-06-2012, 03:12 PM Thread Starter
sevenscrew
okay thanks will try that
2016 2DR JK
post #9 of 25 Old 05-06-2012, 03:30 PM
JasonStebbins
If it was four quarts low for an extended period of time I wouldn't invest too much into the motor. Is it a tap or a knock? My tap goes away with the above suggested Marvel Mystery Oil but if it continues while warm with RPM it sounds more like a rod.
Poop
post #10 of 25 Old 05-06-2012, 05:54 PM Thread Starter
sevenscrew
when i get off the valve cover for the gasket change, is there anything i can look for to find the tap easily? or is it very hard to find the bend. if its a rod i can change that easily by taking the bolt out of the rocker arm, then just remove the rod and put a new one in right?
its a tapping ish almost a click sound. you dont really feel it through the floor or pedal or anything so i wouldnt say a knock. ill try getting a vid up tomo.
2016 2DR JK
post #11 of 25 Old 05-06-2012, 06:28 PM Thread Starter
sevenscrew
not sure if this is related, but the oil pressure was obviously at 0 with no oil in it, thats when i checked it halfway home, and added 4 quarts at advanced. then it went back to 39ish stably. now when it idles it hovers around 25, then if i step on it to around 1500 give or take, it is back up around 39. then i let off drops to 25 ish..
Its a tapping and is faint, but loud enough to hear witht he hood closed.
2016 2DR JK
post #12 of 25 Old 05-06-2012, 06:32 PM
MurdaJs
any ideas ?
Exhaust leak somewhere?
MurdaJs is offline
post #13 of 25 Old 05-06-2012, 06:36 PM Thread Starter
sevenscrew
its from the engine bay, and like near the center of the intake manifold area, didnt use a stethoscope or anything. sound wasnt louder or anything with new exhaust, just now you can hear it more because the exhaust isnt so loud lol
2016 2DR JK
post #14 of 25 Old 05-06-2012, 06:40 PM
MurdaJs
leaky exhaust manifolds sounds are often described as clicking/tapping and match rpms
MurdaJs is offline
post #15 of 25 Old 05-06-2012, 06:43 PM Thread Starter
sevenscrew
how can i check? just look for visible cracks? stethoscope the manifold witha long screw driver?
2016 2DR JK
