4.0 start only after check engine light - JeepForum.com
post #1 of 4 Old 07-20-2009, 05:18 PM Thread Starter
marinejeep6122
my 4.0 hasnt been running very well lately. one day on the road it just up and dies on me. towed it back the next day and tried to start and nothing, tried again later and only after the check engine light comes on does it crank over and start. other then that it just cranks and cranks. the whole starting only after the check light comes on has been the norm while ive owned it.
replaced wires, plugs, fuel filter, crank position sensor. i get pressure in the fuel line. when it does start it will run totally fine for 10-20 minutes. ive been leaning towards a dying ECM. any other ideas? checked all fuses and all are good.
marinejeep6122 is offline
post #2 of 4 Old 07-20-2009, 07:12 PM Thread Starter
marinejeep6122
also usually the main fuse box clicks and then a couple quick short clicks then the light comes on
post #3 of 4 Old 07-20-2009, 07:42 PM
RJV
why is the check engine light on, what code is stored ecm?
RJV is offline
post #4 of 4 Old 07-21-2009, 02:25 PM Thread Starter
marinejeep6122
when i can actually get codes, its just 12 (ecm lost power within the last 50 key cycles) and 55 (end codes). i try to check after it dies but a cant pull anything up. i did check the cap and rotor last night and noticed the rotor has a nice divit in it and a nice chunk missing. maybe this causes the stalling?
Check Engine Light On: 1995 Jeep Grand Cherokee Limited 4x4 4.0 Engine Keith1975 ZJ Grand Cherokee Forum 7 11-04-2014 09:31 PM
Check engine light and ways to check codes cody11ca ZJ Grand Cherokee Forum 12 01-11-2011 08:04 PM
Solid check engine light, no code, no start. skidmark421 ZJ Grand Cherokee Forum 7 05-25-2009 03:03 PM
0 oil pressure and no check engine light? Also what trigers major check engine fault SPL Tech ZJ Grand Cherokee Forum 9 01-08-2007 07:28 AM
94 Grand won't start no check engine light fflint_410 ZJ Grand Cherokee Forum 4 11-25-2005 09:10 AM
