4.0 Stalling when stopping/stopped/idle, and loss of power/bucking when accelerating? - JeepForum.com
post #1 of 18 Old 06-08-2012, 08:16 PM Thread Starter
JeepinJordan
Could it be a bad tps or cps, something else? It starts up and runs fine when it wants to, but then at any random stop light, it just studders and stalls. When it does that I just start it back up and it sometimes gives me trouble staying on. Few minutes ago it stalled when I was braking to a stop sign. Also, today it had a hard time accelerating, like it was running out of gas and bucking. This started happening about a month ago, more frequent recently. No CEL or any indication light.
96 GC, 4.0, Has 183,000 miles. Thanks.
EDIT: Forgot to mention, I recently cleaned out my IAC and TB.
EDIT: I started it up today, checked sensors cold and warm (the stalling was worse when driving warm) and nothing seemed to stall out or hesitate. So then my last test was the PCM and the second I touched the first closest connector, it stalled out. PCM IS THE CULPRIT HERE
EDIT: SAME DAY. Let it cool down and then tryed the PCM test again. It did not try to die when touching the connection this time. Cleaned the PCM ground by the oil dipstick tube, started it up and drove for a little. Died two times around my community, started right up. Drove back home and let it run in my driveway, while trying to mess with the pcm for the third time. Did not try to stall.
EDIT: SAME DAY. reset the PCM, followed this: http://www.jeepforum.com/forum/f13/q...et-pcm-948495/
Seems to run fine, no stalling yet, drove it around the block a good 4-5 miles
JeepinJordan is offline
post #2 of 18 Old 06-08-2012, 08:26 PM
vol96
wiggle some wires at the sensors that would be my guess since it sounds random and sudden.
vol96 is offline
post #3 of 18 Old 06-08-2012, 08:37 PM
hdrocknroll
Take a look at my thread !
NO, start,started, now it's dying. While Ideling
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #4 of 18 Old 06-08-2012, 09:02 PM Thread Starter
JeepinJordan
Originally Posted by hdrocknroll View Post
So the sensors didn't do a damn thing? Just bad connections? I thought it was my battery terminals and posts last week because it wouldnt start up at all and the under hood light was flickering dim, all after a day of stalling at every stoplight. So i used a battery terminal brush and cleaner. started up and ran fine for a couple of days, but then the stalling started to happen again.
-Bone stock 1996 Jeep Grand Cherokee Laredo 4.0L
post #5 of 18 Old 06-08-2012, 09:08 PM Thread Starter
JeepinJordan
IT DOES THIS! I cant believe I found this on youtube, its exactly the same.
http://www.youtube.com/watch?feature...5IVqURR2E&NR=1
post #6 of 18 Old 06-08-2012, 09:52 PM
hdrocknroll
If I remember right those guys want you to pay them to tell you to put zip ties on your PCM.
Don't pay them.
It could be your crank sensor, it could be your PCM, it could be you need to clean your grounds,it could be a fuel problem, or something else.
But it won't cost you anything you clean your grounds.
I just thought it would be good to read my thread to get some ideas.
Good luck
post #7 of 18 Old 06-08-2012, 10:07 PM Thread Starter
JeepinJordan
Don't pay them.
Good luck
Oh no, I checked the website and it was sketch as hell. But yes I will check the grounds and putt putt around untill it starts acting up again. I just would like to know what sensor it is more likely to be. Not trying to replace something I dont need with something not OEM.
post #8 of 18 Old 06-08-2012, 10:14 PM
hdrocknroll
I would say most likely sensor would be crank sensor
post #9 of 18 Old 06-08-2012, 10:23 PM
ZeeJay1997
Did you wiggle the PCM plugs while idling? Sounds familiar.
ZeeJay1997 is offline
post #10 of 18 Old 06-08-2012, 10:27 PM Thread Starter
JeepinJordan
yeah, did nothing.
post #11 of 18 Old 06-09-2012, 09:50 AM Thread Starter
JeepinJordan
Well guys its not any sensors. It is my PCM. Warmed it up and messed with every sensor, then last I messed with the PCM connections and it kept stalling out.
I have work tonight, any info on how to rig this for a day or two untill I get a day off. I've seen zip ties?
I will probably end up cleaning out the pcm before I buy a new one. Just dont think I have time today.
post #12 of 18 Old 06-09-2012, 09:56 AM Thread Starter
JeepinJordan
Advixe would be appreciated. I never cleaned one, only seen a write up with only words, no pictures. If the cleaning doesnt work, where should I go about getting a new PCM without being raped, lol I hear they arent cheap.
post #13 of 18 Old 06-09-2012, 10:53 AM
Oldfrog
2007 WK
Cleaning the plugs only resets it most of the time, because you'll need to disconnect the battery before cleaning it.
Go get an "A-1 Cardone" brand PCM from Oreilly's for $249 or so and be done with it. Do NOT order one online from either of those outfits in Florida.
There's also a good write up on this site showing how to fix it yourself if you're so inclined.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #14 of 18 Old 06-09-2012, 10:59 AM Thread Starter
JeepinJordan
Read my recent EDITS. I am lost!
post #15 of 18 Old 06-27-2013, 06:34 PM
Jcamaro123
please advise on where this write up is...
where's this write up - I would like to try this. Thank You
(My 95 GC 5.2 is stalling out at stop sign)
Jcamaro123 is offline
Rough idle/miss power loss fdawg4ever ZJ Grand Cherokee Forum 0 06-07-2012 09:10 PM
Ocassional bucking/loss of power... check engine light ERICH ZJ Grand Cherokee Forum 12 06-20-2011 12:35 PM
Experiencing loss of power and stalling murphydajeep ZJ Grand Cherokee Forum 10 05-10-2010 12:44 AM
Rough Idle, Loss of Power --> My fix Gorgle ZJ Grand Cherokee Forum 7 09-03-2007 05:57 AM
Help Jeep Bucking/ Power Loss princessjen ZJ Grand Cherokee Forum 8 09-30-2005 04:07 PM
