-   -   4.0 Stalling when stopping/stopped/idle, and loss of power/bucking when accelerating? (http://www.jeepforum.com/forum/f13/4-0-stalling-when-stopping-stopped-idle-loss-power-bucking-when-accelerating-1378987/)
JeepinJordan 06-08-2012 08:16 PM
Could it be a bad tps or cps, something else? It starts up and runs fine when it wants to, but then at any random stop light, it just studders and stalls. When it does that I just start it back up and it sometimes gives me trouble staying on. Few minutes ago it stalled when I was braking to a stop sign. Also, today it had a hard time accelerating, like it was running out of gas and bucking. This started happening about a month ago, more frequent recently. No CEL or any indication light.
96 GC, 4.0, Has 183,000 miles. Thanks.
EDIT: Forgot to mention, I recently cleaned out my IAC and TB.
EDIT: I started it up today, checked sensors cold and warm (the stalling was worse when driving warm) and nothing seemed to stall out or hesitate. So then my last test was the PCM and the second I touched the first closest connector, it stalled out. PCM IS THE CULPRIT HERE
EDIT: SAME DAY. Let it cool down and then tryed the PCM test again. It did not try to die when touching the connection this time. Cleaned the PCM ground by the oil dipstick tube, started it up and drove for a little. Died two times around my community, started right up. Drove back home and let it run in my driveway, while trying to mess with the pcm for the third time. Did not try to stall.
EDIT: SAME DAY. reset the PCM, followed this: http://www.jeepforum.com/forum/f13/q...et-pcm-948495/
Seems to run fine, no stalling yet, drove it around the block a good 4-5 miles
vol96 06-08-2012 08:26 PM
wiggle some wires at the sensors that would be my guess since it sounds random and sudden.
hdrocknroll 06-08-2012 08:37 PM
Take a look at my thread !
NO, start,started, now it's dying. While Ideling
JeepinJordan 06-08-2012 09:02 PM
Originally Posted by hdrocknroll (Post 13693887)
So the sensors didn't do a damn thing? Just bad connections? I thought it was my battery terminals and posts last week because it wouldnt start up at all and the under hood light was flickering dim, all after a day of stalling at every stoplight. So i used a battery terminal brush and cleaner. started up and ran fine for a couple of days, but then the stalling started to happen again.
JeepinJordan 06-08-2012 09:08 PM
IT DOES THIS! I cant believe I found this on youtube, its exactly the same.
http://www.youtube.com/watch?feature...5IVqURR2E&NR=1
hdrocknroll 06-08-2012 09:52 PM
If I remember right those guys want you to pay them to tell you to put zip ties on your PCM.
Don't pay them.
It could be your crank sensor, it could be your PCM, it could be you need to clean your grounds,it could be a fuel problem, or something else.
But it won't cost you anything you clean your grounds.
I just thought it would be good to read my thread to get some ideas.
Good luck
JeepinJordan 06-08-2012 10:07 PM
Don't pay them.
Good luck
Oh no, I checked the website and it was sketch as hell. But yes I will check the grounds and putt putt around untill it starts acting up again. I just would like to know what sensor it is more likely to be. Not trying to replace something I dont need with something not OEM.
hdrocknroll 06-08-2012 10:14 PM
I would say most likely sensor would be crank sensor
ZeeJay1997 06-08-2012 10:23 PM
Did you wiggle the PCM plugs while idling? Sounds familiar.
JeepinJordan 06-08-2012 10:27 PM
yeah, did nothing.
JeepinJordan 06-09-2012 09:50 AM
Well guys its not any sensors. It is my PCM. Warmed it up and messed with every sensor, then last I messed with the PCM connections and it kept stalling out.
I have work tonight, any info on how to rig this for a day or two untill I get a day off. I've seen zip ties?
I will probably end up cleaning out the pcm before I buy a new one. Just dont think I have time today.
JeepinJordan 06-09-2012 09:56 AM
Advixe would be appreciated. I never cleaned one, only seen a write up with only words, no pictures. If the cleaning doesnt work, where should I go about getting a new PCM without being raped, lol I hear they arent cheap.
Oldfrog 06-09-2012 10:53 AM
Cleaning the plugs only resets it most of the time, because you'll need to disconnect the battery before cleaning it.
Go get an "A-1 Cardone" brand PCM from Oreilly's for $249 or so and be done with it. Do NOT order one online from either of those outfits in Florida.
There's also a good write up on this site showing how to fix it yourself if you're so inclined.
JeepinJordan 06-09-2012 10:59 AM
Read my recent EDITS. I am lost!
Jcamaro123 06-27-2013 06:34 PM
please advise on where this write up is...
where's this write up - I would like to try this. Thank You
(My 95 GC 5.2 is stalling out at stop sign)
The time now is 03:53 AM.
