Quantcast 4.0 Questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 4.0 Questions
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Old 08-19-2006, 12:45 PM   #1
dadstoy
4.0 Questions
Ok, I thought this would be the best place to ask some questions about the 4.0/auto I just installed in my Jeep. The donor was a 95 Grand. It was involved in a roll over accident. I have the motor and tranny installed in my YJ, but am having issues. Finally got the start circuit figured out and it runs, but only for about 10 seconds then dies. This is at idle only. If I apply fuel, it will stay running, but run rough. Let off the gas, it dies. I am not sure if the Grand had the security on it or not. I won't be able to find out until Monday. Someone suggested the TPS or the CPS. Any ideas? Any help is greatly appreciated.
Dave
dadstoy is offline   Reply With Quote
Old 08-21-2006, 04:33 PM   #2
PugetHound
did you swap the ECU also ?
PugetHound is offline   Reply With Quote
Old 08-21-2006, 10:08 PM   #3
Woody
Retired back to Bowties
Woody's Avatar
1985
I bet the ECU has a security system built in. You probably don't have the proper wiring from the BCM (body control module) to give it the signal it wants to confirm the alarm has been disabled.
You may have to order a new ECM without the security.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline   Reply With Quote
Old 08-22-2006, 10:39 AM   #4
PugetHound
An ECU from a manual shift vehicle plugged into an auto would do the same thing I think.
Old 08-22-2006, 12:26 PM   #5
dadstoy
Turns out it was the security/anti-theft that was the problem. I tried a ECM from a YJ 4.0/auto and it ran fine. I ordered another last night.
Thanks
Old 08-22-2006, 12:34 PM   #6
PugetHound
Glad you fixed it !
Glock Forum
