4.0 problems, BAH! - Page 2 - JeepForum.com
post #16 of 31 Old 08-21-2013, 02:45 PM Thread Starter
Martin600
Okay, I got codes
12
25
22
27
51
55
Is there a thread which lists these codes?
I know one of them is IAC, because my dad unplugged it with the engine running. (and god knows what else, I wasn't there)
Are they stored in the order in which they were triggered?
Martin600 is offline
post #17 of 31 Old 08-21-2013, 02:54 PM
JeepNicholson
Originally Posted by Martin600 View Post
Okay, I got codes
12
25
22
27
51
55
http://www.allpar.com/fix/80s-codes.html
If you've got a smart phone, there are also a few free apps that, well, decode the codes. I use one called OBD Error Codes that decodes both old style and obdii codes, and it's handy to have with you all the time.
JeepNicholson is offline
post #18 of 31 Old 08-21-2013, 03:28 PM Thread Starter
Martin600
Ahh good thinking! Pity, I've got the Torque app and it doesn't have the old codes
Okay, ignoring 12, 25, 27 (some of the injectors were unplugged) and 55.
Leaves me with code 22 and 51.
22. Coolant sensor signal out of range? Where is the coolant sensor? I find a sensor on the engine but appears to be just for the temp gage in the car?
It can't be the coolant level sensor in the reservoir, I've tested that already. it was 3.2kohm at "full" and 0 at empty.
51, O2 sensor stuck in lean position. Possible bad map sensor (that would explain the black smoke, rough idling and rich smelling exhaust fumes at hot idle?)
Is there any way I can test the map sensor, resistances etc?
Thanks for all the help so far
post #19 of 31 Old 08-21-2013, 03:49 PM
JeepNicholson
The engine temp gauge on your dash gets its info from the coolant temp sensor, because if your coolant is too hot, your engine is too hot. Though not to be confused with the ambient air temp which is just a bonus weather thing and has nothing to do with your engine, of course.
It's on the driver's side of your engine toward the back, next to your valve cover and sorta under the MAP-
http://www.olypen.com/craigh/images/tempsensor.jpg
Not sure about the map sensor though as I've never had any issues with mine, though I might remember reading that the map sensor code could have something to do with a bad or dirty IAC and possibly not the actual map, but don't quote me on that, because I could be completely wrong, lol. Just something to consider.
Anyway, it certainly won't hurt anything to clean your IAC anyway, and it's quick cheap and easy. Clean the hole it comes out of, too.
ZJ FSM
https://drive.google.com/folderview?...Fk&usp=sharing
post #20 of 31 Old 08-21-2013, 05:52 PM
ZeeJay1997
I would suspect that dad unplugged the coolant sensor too since it lives near the injectors.
The lean o2 sensor would cause your symptoms. Unplug the front sensor and see how it runs. the connector is under the manifold.
ZeeJay1997 is offline
post #21 of 31 Old 08-22-2013, 04:05 PM Thread Starter
Martin600
Doing a 200 mile round trip tomorrow, unplugged the front lambda sensor, will let you know how it gets on
Will upload pics of my engine bay shortly, so you can see what I'm dealing with. The description and pictures shown to me do not match what I have.
That's 100% alternator in the way of No.1 spark plug and there's no air compressor
post #22 of 31 Old 08-22-2013, 04:07 PM Thread Starter
Martin600
The image at the top shows the sensor which controls the signal to the temp gage in the car.
post #23 of 31 Old 08-22-2013, 04:31 PM
JeepNicholson
You don't, and never had AC?
post #24 of 31 Old 08-22-2013, 04:55 PM Thread Starter
Martin600
Aircon? yeah it has that, and it's all there and it works
I thought you meant it had an air pump like for emissions and stuff.
post #25 of 31 Old 08-22-2013, 04:59 PM
JeepNicholson
Lol I was just wondering, cause on the 4.0 the compressor for your AC normally sits above your alternator right next to that first plug. From the pics though, I see that isn't the case. Where IS your a c compressor?
But no, not a regular air compressor lol
That would be useful though, my buddy has one on his Ram 2500 Cummins, he can hook his air tools right up to his truck, and the tank sits underneath the frame. Pretty sweet.
ZJ FSM
post #26 of 31 Old 08-22-2013, 06:01 PM
ZeeJay1997
This like Where's Waldo. lol
it appears the compressor is mounted under the alternator base on the cooloant lines.
little peice of advice that may solve your problem.
get some new plug wires and route your coil wire so it does not cross the plug wires. it looks like #2 show some signs of arcing. open the hood at night and rev it up and check for blue lights.
the throttle body needs some serious cleaning.
the stud for the hot wire on the alternator looks like it's rusty
the #1 injector connector looks like it's growing something. all of the connectors need to be cleaned.
change out the idler pully or it will eat your belt
look inside the PDC for other wild life.
sorry if i sound critical, i inspect things for a living and trying to help
post #27 of 31 Old 08-23-2013, 01:23 AM
Oldfrog
2007 WK
Wow, I've never seen a 4.0 with the alternator on top of the A/C compressor. Is that a mod some one did, or did some ZJ's come like that?
The brake master cylinder is on the passenger side ? swapped with the coolant bottle? This is a 97 model? Not a USA model, I am assuming.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #28 of 31 Old 08-23-2013, 05:14 AM
89arkansasxj
This is an RHD rig and it's in the UK I'm betting.
89arkansasxj is offline
post #29 of 31 Old 08-23-2013, 10:53 AM Thread Starter
Martin600
I'd rather someone just got to the point, I've been on many other forums and people seem so unsure when they reply or give generic googled advice.
I'll get right onto those things, I did suspect arcing.
Uhh, brake MC is on your passenger side, yes. Not a USA model.
You bet right, it's a 1997 ZG
UK RHD, also I think it's the ZG down under as well.
In the UK, we also have a 2.5 TD option as well - which is great for towing and having fun in the hills, as long as you watch the water temp because the gaskets are famous for failing - it was designed as a boat engine after all.
post #30 of 31 Old 08-26-2013, 02:53 PM Thread Starter
Martin600
Okay! results!
Unplugged the first lambda sensor, been driving it about (over 300 miles) and not even a single splutter out of it. it's "fixed".
So, I've got a dead lambda sensor? OR a worn MAP sensor? what's most likely?
