4.0 I6 Maintenance - JeepForum.com
post #1 of 3 Old 10-04-2008, 08:56 PM Thread Starter
amargill19
4.0 I6 Maintenance
Hey guys,
the girlfriend's jeep is comin' up on about 135,000 kilometers.... (2001 WJ jeep w/ 4.0L and selec-track 4wd)
I do not know the service history of this vehicle, we've had it since about 120,000km
So far I've done a couple oil changes and the front brakes/rotors (i noticed the calipers were the upgraded akebono ones)
Some of the things I'm going to check when i do an oil change and flush/replace if required:
Front/Rear diff fluid (will probably replace rear diff fluid)
Trans fluid, T-case fluid (probably will flush trans fluid)
Power steering fluid (makes some noise, will flush)
brake fluid is ok.
I'm sure the coolant is fine for a while longer
grease the two areas on the front suspension
Is there a plug for a certain cylinder that gets dirtier/worse than the rest? Not sure if/when spark plugs were done, so I want to pull one or two and check them. It's been a while since I've poked my head under the hood, but, is this a coil on plug setup? Easy to do the plugs ? (most inline engines are)
And lastly, There would appear to be a bit of an oil sweat from the pan? Although it doesn't leak much to see it on the ground (and I'm not adding any) I noticed the rubber grommets on the valve cover (PCV system??) have a bit of oil residue around them, are there kits to clean/replace the crankcase breather?
sorry 'bout the long post. Thanks for the help in advance!
amargill19 is offline
post #2 of 3 Old 10-04-2008, 09:00 PM Thread Starter
amargill19
also threw a CEL earlier today, the girlfriend says.
It has thrown a few CEL's before, but they go away. I plugged the modus in one time and it said "EVAP VERY MINOR LEAK" etc but it has always gone away shortly after...
I will try and get my hands on a code reader to check it.
Anyone know a good place online to buy a new rear driver's side taillight assembly?
post #3 of 3 Old 10-05-2008, 03:59 AM Thread Starter
amargill19
Oil Changes – DIY Maintenance Indian WK Grand Cherokee & XK Commander Forum 14 11-09-2009 10:11 PM
Help With Maintenance JOHNRAMBO WK Grand Cherokee & XK Commander Forum 1 11-19-2008 11:22 PM
CRD maintenance tcmglx WK Grand Cherokee & XK Commander Forum 0 02-06-2008 12:29 AM
Maintenance twmattox ZJ Grand Cherokee Forum 5 02-20-2006 01:58 PM
i need all the maintenance help available... Derek33 ZJ Grand Cherokee Forum 2 06-18-2004 12:55 PM
