4.0 HO? - JeepForum.com
post #1 of 20 Old 12-01-2001, 01:50 PM Thread Starter
redneckwithajeep
4.0 HO?
how would i go about making my zj 4.0 a HO engine? whats the difference? any help appreciated!
'86 xj, 2.8, 3" lift
'94 zj, 4.0, stock (Sadly)
redneckwithajeep is offline
post #2 of 20 Old 12-01-2001, 01:55 PM Thread Starter
redneckwithajeep
also: are those throttle body spacers really any good? or can i just bore a piece of aluminum from the throttle body gasket as a template and get the same results? and is thicker better? too thick and i'd have a problem with hood clearance tho.
post #3 of 20 Old 12-02-2001, 12:57 PM
Kess
the 4L HO, is a v6 setup, the only way to make ur zj a HO you would have to swap engines with a V6 ho from ur basic L6, go here for the throttle body spacer,poweraide, http://www.truckperformance.com/prod...der=&sf1=JEEP& sf2=1994&sf3=GRAND+CHEROKEE&sf4=4.0L
poweraide TBS
i think thicker is better to an extent, then clearence comes in and im guessing that if you get to greedy that the hightened TB will start to lack power
In comission:2004 WJ, stock....
Retired:1994 JGC Laredo I6 4.0L, Smittybilt Outland brush guard, 1 3/4" Daystar coil spacers, custom air intake with tube K&N, Borla cat-back, KC Daylighters 6" 150w stainless steel, Xenon superwhite headlights 85/100w, 235/75/15 Pirelli Scorpian A/T, billit aluminum grill inserts
Kess is offline
post #4 of 20 Old 12-03-2001, 02:50 AM
horatio102
Not exactly sure what you're talking about. I don't know of any I6 (it's an I, as in inline, is it not? Some fonts use a lowercase L as a capital i, which is where confusion comes in.) H.O. units. There is a HO 4.7L v8 in the new WJs, and Ford made HO 4.9L v8's for years in the Mustang 5.0. Your 4.0L puts out 190hp/235ft-lbs, the current 4.0 puts out 195hp/230ft-lbs, so I'm again not sure what you want.
horatio102 is offline
post #5 of 20 Old 12-03-2001, 03:05 PM Thread Starter
redneckwithajeep
obviously u guys know alot more about this than i do, but i know the 4.0 HO is an inline 6. my friend a while ago had a xj w/a 4.0 ho, and it was inline six, also ive worked on cars with them.
post #6 of 20 Old 12-04-2001, 12:28 AM
horatio102
Oh. I think I know what you're talking about.
The old 4.2L 6 was called High Power or something, because it had low horsepower but loads of torque. Then the new High Output (fuel injected) 4.0L came out.
post #7 of 20 Old 12-07-2001, 01:30 PM
Fierce ZJ
What was that V6 thing all about??? Your 4.0 is a high output 4.0. So you don't have to do anything to make it a HO.
Fierce ZJ is offline
post #8 of 20 Old 12-07-2001, 03:07 PM
horatio102
I think he's talking about the Ford Ranger/Exploder V6.
post #9 of 20 Old 12-08-2001, 08:34 AM Thread Starter
redneckwithajeep
i dont know what the v6 thing was about, i have an 86 xj w/a 2.8 V6 but im talking about the 4.0. also, unless they put the 4.0 High Output in the zj's, {stock} i dont have one.
post #10 of 20 Old 12-08-2001, 02:50 PM
horatio102
The V6 thing was because you asked about a H.O. 4.0L
Ok here's the poop.
'90 and older 4.0L XJs put out 177 hp and 224 lb-ft torque.
In '91 it got bumped via minor tweaking (lower compression for one) up to 190hp/235lb-ft
For 2001, the torque was dropped down to 225lb-ft, to make the Liberty look better on paper.
ZJs from '93 to '95 had 190/235, then it dropped to 185/220 between '96 and '98, and up to 195/230 from '99 on up.
Since you've got the '94, you've got 5hp less than current, but 5 lb-ft more. Now. What do you want to do about it?
I really don't know what the fuss is about. These #s were gathered from carpoint.msn.com and I do not guarantee their accuracy.
post #11 of 20 Old 12-08-2001, 09:18 PM
Neil
All ZJ 4.0's were HO. The older Cherokee 4.0 was not considered an HO. Not sure but I think the HO started in 91- or 92
5.9 ZJ
98 ZJ 5.2
Neil is offline
post #12 of 20 Old 12-08-2001, 10:19 PM Thread Starter
redneckwithajeep
horatio & neil, that really helped, thanx
post #13 of 20 Old 12-09-2001, 01:19 PM
Brendan
All of the 91 and newer 4.0 L were high output. If you look at the 91 Wrangler stickers they say 4.0 H.O. beacuse they have a much higher flow head design, as compared to the old 4.2. There is no v6 jeep engine besides the old buick engines that were used in a hand full of CJs. There are some cherokees that had a EFI 4.0 that wasn't high output, but the ones with the new head design are HO whether they say it or not.
Duvie
95 YJ 2.5L 5 Speed
Fightin a war against Florida Rust!
Brendan is offline
post #14 of 20 Old 12-09-2001, 04:52 PM Thread Starter
redneckwithajeep
that helped, but i think you're slightly mestaken. the buick engine was put into the cherokees but nobody wanted them because of their lack of power. i know this because i have one.
post #15 of 20 Old 12-19-2001, 08:34 PM
The^Knightmare
heres a simple question....does the inline 6 that I have in my 94 Grand Cherokee laredo have enought power or should I get a bigger ( or add more performance options ) engine
94 JGC Laredo sorta stock
- K&N Custom Air Intake
- 20x8.5 Enkei AKAs
- 3JL 12W6s w/ Kicker ZR600
The^Knightmare is offline
