4.0 hesitation, miss, after a few miles - JeepForum.com
post #1 of 7 Old 08-04-2009, 02:56 PM Thread Starter
sterlingmarlin3
starts up fine, 2 miles on the road it misses, hesitates, backfires then smoothes out works fine, if i shut it off and restart, hesitation is gone. new plugs, no codes, 270,000 any ideas?
sterlingmarlin3 is offline
post #2 of 7 Old 08-04-2009, 03:34 PM
amonostereo
did it start this after the new plugs went in, or was it this problem which prompted the new plugs?
does it do this at 2 miles every time you take it out? or is it just after a certain time running?
'93 5.2L V8, Laredo, 242 TC swapped from a 249, 3" Coils up front and Front coils in the Rear, JKS Adjustable Track bar, K&N Cold Air Intake with Amsoil filter, Rear cargo area shelving, and KOR's Steering Gear Brace, IRO's Over-The-Knuckle Steering, Top Light Rail, Top Tire Carrier... for now...
OR If you prefer acronyms: 93 5.2 V8, 249>242, 3" FC, ~2" RC, JKS Adj. TB w/ KOR TB Bracket, K&N CIA w/ Amsoil filter, Shelves, KOR SB, IRO OTK HD steering
amonostereo is offline
post #3 of 7 Old 08-04-2009, 03:50 PM
newfieZJ
It helps to know what you drive , fill out your info please
Sounds like the upsteam 02 sensor , if a 96 or newer
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #4 of 7 Old 08-04-2009, 05:05 PM
SUfan
It could be the egr valve. They tend to go bad after a while< just had the same problem with mine popping, missfire ect. changed it and it ran like new again.
SUfan is offline
post #5 of 7 Old 08-05-2009, 12:36 PM Thread Starter
sterlingmarlin3
it happens the same time each time about the 2 mile mark, warm or cold, platnum plugs were just routine, seems to happen more now
post #6 of 7 Old 08-06-2009, 04:12 PM
newfieZJ
Try unplugging the upstream (closest to the engine) 02 sensor . This will cause a engine light but does no damage if just doing the test . Drive it a few days . If the issue goes away , replace the senser with a Mopar unit . I'll describe the symptoms
Happens only within 3-5 minutes of starting , can be cold or warmed up .
Stumbling and backfiring lasts for approx 30-45 seconds , then , just clears up (backfiring most likely a result of trying to accelerate while this occurs)
Once finished it's little hissy fit , it will run all day without issue , provided it's not shut off .
If that's whats happening , skip the test , install sensor
1995 Orvis build
1988 MJ build
newfieZJ is offline
post #7 of 7 Old 08-07-2009, 02:30 PM Thread Starter
sterlingmarlin3
thats exactly what its doing, many thanks
Miss my WJ, need advice bigjeep39 ZJ Grand Cherokee Forum 9 04-16-2009 03:01 PM
Bad miss in I6 4.0 blackbeard52 ZJ Grand Cherokee Forum 1 10-23-2008 12:24 PM
I miss my first Packy ZJ Grand Cherokee Forum 16 04-10-2007 07:36 PM
Slight Hesitation / Miss at Highway Speed Jammer73 ZJ Grand Cherokee Forum 0 02-17-2007 08:22 AM
i think its miss firing 2tone93zj ZJ Grand Cherokee Forum 1 02-05-2007 11:53 PM
