4.0 GC Quits running - JeepForum.com
post #1 of 8 Old 12-06-2006, 02:50 PM Thread Starter
simsup
My 1999 GC Laredo quits running (turns off). It was just a idle but now it happens when going 45-50 mph. The code that is set is P320. After it quits you can crank the engine and it just cranks and nother happens. Seems that turning the key off then back on then cranking will allow it to start. This restart only takes a 5 secs or so. Not sure if the key off thing is a clue or not. Code says crank sensor not seen during cranking. I have checked the cable and ground. Seem good. I am thinking about swapping the crank sensor out. Fuel pressure is good.
So can these crank sensors fail intermittent and if it did should I get some other codes? This is the only one that I get. Also I have reset the codes and when it quits the P320 reappears. Any ideas out there?
simsup is offline
post #2 of 8 Old 12-06-2006, 02:54 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Replace the CPS and go from there.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 8 Old 12-06-2006, 03:02 PM
mdsuave13
mdsuave13's Avatar
yea.. the codes that come up, come up for a reason usually, unless you completely submerge your jeep in water during a river crossing, and everything starts coming up till it all dries out
Safari'd out ZJ.
mdsuave13 is offline
post #4 of 8 Old 10-21-2014, 06:31 AM
clcrump
Simsup,
Did you ever get this problem figured out? My 2002 jeep wrangler is doing what sounds like the exact same thing. What did you find?
clcrump is offline
post #5 of 8 Old 10-21-2014, 03:34 PM
mikem350
1994 ZJ
First thing is to scan for codes...and try to clear them! The engine computer self diagnoses. Then repost for advice....
Proud owner of two ZJs
Red 94 mint!
Silver 98 just hit 300k miles....runs like new!
mikem350 is offline
post #6 of 8 Old 10-21-2014, 11:49 PM
shaban
Use Mopar sensors, others may work but can give a lot of troubles.
shaban is offline
post #7 of 8 Old 10-23-2014, 08:21 PM
clcrump
It's not showing any codes ... Except when I turned the key off and on three times, it showed p0320. Is that for the crank sensor?
clcrump is offline
post #8 of 8 Old 10-23-2014, 08:40 PM
shaban
That's:
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
Possibly the crank sensor or cam angle sensor in the distributor.
I'd replace the crank angle with a new Mopar part and go from there.
shaban is offline
ZJ 5.9 runs, quits & won't start...... IMin4Low ZJ Grand Cherokee Forum 2 03-10-2009 05:28 PM
idles down then quits nursematt ZJ Grand Cherokee Forum 1 11-07-2006 10:41 AM
speedo jumping and sometimes quits? 02Lightning ZJ Grand Cherokee Forum 4 12-08-2005 09:47 AM
engine quits :mad: zbigniew ZJ Grand Cherokee Forum 2 07-09-2005 01:41 PM
Starts & Quits--Sometimes? Herb Jenssen ZJ Grand Cherokee Forum 2 12-01-2002 01:56 PM
