Quantcast 4.0 GC cranks but will not start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 4.0 GC cranks but will not start
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 01-12-2010, 08:48 AM   #1
rfoster60
My '94 GC started yesterday with no problems. When I put it in drive, the engine died and now will not start. It turns over good but doesn't try to start. Any thoughts on what to check, fuel delivery?, electrical? security system? Any ideas would be appreciated.
rfoster60 is offline   Reply With Quote
Old 01-12-2010, 01:26 PM   #2
eshew
Check fule pressure by way of the large schraeder valve on teh fuel rail. Should be about 30 psi. If it gives you a good spray, check your spark. Could be a dead coil or dead fuel pump. Both are garage fixes.
eshew is offline   Reply With Quote
Old 01-12-2010, 05:24 PM   #3
benspilk09
Remove a plug and check if it is wet. Check your spark also. If you have neither spark or fuel, and you have fuel pressure, its probably your crank sensor.
benspilk09 is offline   Reply With Quote
Old 01-14-2010, 05:32 PM   #4
rfoster60
I had it towed home and tried some basic tests (check fuses, relays). They checked ok. No pressure at schraeder valve on fuel rail. I performed a highly technical test of hitting the bottom of the gas tank while having someone try to start and it actually started. It will run as long as I hit the bottom of the tank but dies immediately when I stop. Is this conclusive proof that my fuel pump is gone or could it still be something else. Thanks.
Old 01-14-2010, 06:14 PM   #5
benspilk09
Can you hear your fuel pump run when you turn on the key?
Old 01-14-2010, 06:51 PM   #6
rfoster60
I do not hear the fuel pump at all when I turn on the key and nothing happens unless I hit the bottom of the tank. It spits and sputters but starts while hitting the tank but dies when not hitting it. Is there a more conclusive test I can perform to determine if the fuel pump is bad?
Old 01-14-2010, 06:55 PM   #7
blobo
2010 JK Wrangler
could be way off here but my 95 would crank very well but just wouldnt turn over till i pumped the gas a few then it started right up... very small thing but maybe itll do it
blobo is offline   Reply With Quote
Old 01-14-2010, 07:13 PM   #8
benspilk09
If you don't hear your fuel pump its not going to run, take it out and power it up and see if it runs/pumps. If it works its probably in the wiring somewhere.
Old 01-14-2010, 08:09 PM   #9
rooster51
You already proved to yourself and us that its the fuelpump.
Good Job.
rooster51 is offline   Reply With Quote
Glock Forum
