4.0 94 ZJ crank but won't start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 4.0 94 ZJ crank but won't start
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 11-05-2009, 10:54 AM   #1
sixone
tried to start the car today but the engine does not fire at all..
after some check-ups i got to the conclusion that the gas is coming, it has sparks but won't fire..
so what i've tested so far was:
fuel pump - when i turn the key i can hear a noise from the back
fuel pump relay - is sending 12v
i've pressed the fuel gauge on the ramp with a screwdriver (while somebody else was cranking the engine) and gas was flowing out..
i removed all the spark plugs, 3 (2,3,4 cylinders) of 6 were very wet (gas) and the rest of them not as wet as the others (i don't know why)
after i clean them, tried to crank the engine with one spark plug out and got a beautiful spark.. i put them back but no luck..
i'm lost.. i got gas and spark but it won't start.. i've read something about the crank sensor.. but i'm a little bit confused, if i have a good spark, could it be sensor?
sixone is offline   Reply With Quote Quick reply to this message
Unread 11-05-2009, 10:59 AM   #2
mhems001
have you tried drying them out and crankin again? or have you checked your throttle body and IAC to see if they are clean and working?
mhems001 is offline   Reply With Quote Quick reply to this message
Unread 11-05-2009, 11:19 AM   #3
sixone
yes, i cleaned the spark plugs with a dry cloth, brush and even with a lighter.. but the car didn't started..
tried this twice, because after i put them back and run some more tests they got wet again..
throttle body looks okay, more than that i sprayed some starting fluid directly on the throttle body, again with no luck..
i don't know where the IAC sensor is, didn't checked that..
Unread 11-05-2009, 11:29 AM   #4
jeep210
It is not the CPS because you do have a spark. You have a spark plug issue or a fuel issue. Test each plug with its own wire and see what kind of spark you have. If they all look good, then you have to look at fuel.
It sounds like you are getting too much fuel. But, it could be that the plugs are not firing and they get wet.
jeep210 is offline   Reply With Quote Quick reply to this message
Unread 11-05-2009, 11:58 AM   #5
sixone
well.. cleaned the throttle body and iac valve meanwhile, but as i expected still no result.. i tested 2 plugs (after i clean them) and the spark look good.. the plugs don't look very good, they seem a little bit worn out.
the weird part, what i don't understand, if the plugs are faulty why the sudden problem? until today the car started very good.
i will try to change all the spark plugs tomorrow and see what happens..
too much fuel means high pressure on the injector rail? is there any other way of testing the pressure than using a gauge on that valve?
what i also tried few mins ago: take off the fuse and fuel pump relay and sprayed some of that starting fluid directly on the throttle body with the throttle opened. i'm not sure if this supposed to start the car for a few seconds, but nothing happened..
Unread 11-05-2009, 12:08 PM   #6
jeep210
Best to use a pressure gauge to see if you have normal pressure. Autozone may provide a free use gauge. You leave a deposit for the gauge and you get it back when you return. Ask about the free rental.
Hopefully, it will be the plugs. If they look worn then they need replacing. They can develop firing problems that are not visible. I have an aircraft bomb testing machine that tests them under pressure. You can then see the problem easily.
From reading some of the threads, spraying into the TB should have let the engine run for a few seconds. I have never used that technique. Sounds more like no spark. Change out those plugs and see what happens.
Unread 11-05-2009, 12:16 PM   #7
sixone
Okay, will replace them tomorrow.. and post the result here. Any other things to test before i replace the plugs?
Unread 11-05-2009, 03:57 PM   #8
sixone
Because it was too late and all the stores were closed I decided to give it another try and clean the plugs thoroughly. This time i used a blowtorch and some sandpaper, also i adjusted the gap. After all that, they looked like new.. put them back, and .. after a few cranks it started.
Now it runs fine.. i started it couple of times again to be sure and started every time.
Anyway i will replace the plugs by the end of this week, but wanted to let you know what was the problem..
jeep210 was right.
thanks.
