4.0 #5 cylinder misfire - JeepForum.com
post #1 of 3 Old 07-27-2009, 01:53 PM Thread Starter
mrh45
My 2001 grand cherokee misses on #5 cyl throughout rpm range. I changed plugs, coil pack and cam position sensor. Still misses.
It makes a ticking noise and I'm wondering if I have a broken valve spring.
mrh45 is offline
post #2 of 3 Old 07-27-2009, 02:09 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Is it just throwing the code or is it doing anything mechanically?
~James
ezflip is offline
post #3 of 3 Old 07-29-2009, 04:01 PM
20jeepwj00
many times i have seen the #5 or 6 cam lobes wear causing misfires and lifter noise.if the fuel and ignition system check ok it may be the cam .you can also do a leakdown test and rule out any other valvetrain or ring issues.
20jeepwj00 is offline
Misfire cylinder 1 and 6 jeephart ZJ Grand Cherokee Forum 1 05-06-2009 12:50 PM
Cylinder Misfire WK05 WK Grand Cherokee & XK Commander Forum 10 04-02-2009 07:56 PM
#2 Cylinder Misfire? Jimmer ZJ Grand Cherokee Forum 2 09-21-2006 03:41 AM
Misfire on every cylinder? f1rz06 ZJ Grand Cherokee Forum 1 09-12-2004 07:28 PM
Cylinder #4 Misfire Scooter932 ZJ Grand Cherokee Forum 5 05-15-2004 07:53 AM
