360 to 408 ? - JeepForum.com
post #1 of 9 Old 04-25-2013, 06:34 PM Thread Starter
SpenceAK
360 to 408 ?
Bout to pull my 5.9 for rebuild been looking at Hughes engines 408 stroker kit. my plans are for a high torque long mile engine. I'm buying new heads but staying with stock iron heads and rv cam
1. Will my stock computer work with a 408 or is there tuning required?
2. What would be good to upgrade in the valvetrain? Springs rockers......
SpenceAK is offline
post #2 of 9 Old 04-25-2013, 06:44 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Email kolak from my SIG.
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 9 Old 04-25-2013, 07:05 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
rv cam won't be enough for that motor, nor will the "stock" heads. at a minimum you should be running the EQ iron ram 2.02's, the indy rhs x-heads would be a better choice. use a modified kegger intake, and i'd want at a minimum a 510/510 lift cam for it.
you'll need to get the b and g chrysler computer flash for it and at least 24# injectors. though i'd step up to at least 26# to keep the duty cycle lower and the horse power overhead higher.
don't half butt it. if you're building a torque monster motor, build a torque monster motor. get the pistons milled for a 10-10.5:1 compression ratio for some extra grunt. you're going to be needing premium anyways, may as well take full advantage of it.
ratmonkey is offline
post #4 of 9 Old 04-25-2013, 07:21 PM Thread Starter
SpenceAK
A thanks for the advice that's pretty much what I needed to know but I'm afraid that's probably out of my budget. I'd just figured while I got this 360 out maybe I should look into the stroker but still gonna crunch sone numbers. I still gotta lift this thing axle swap , rear gear well you know...
I will email kolak
SpenceAK is offline
post #5 of 9 Old 04-25-2013, 07:24 PM Thread Starter
SpenceAK
Oh and I should mention its not cheap to ship to Alaska!
SpenceAK is offline
post #6 of 9 Old 04-26-2013, 08:39 AM Thread Starter
SpenceAK
what are some good head upgrades for the 360?
SpenceAK is offline
post #7 of 9 Old 04-27-2013, 03:58 PM
Exdecuk
head on over to www.speedfreaks.com and they will point you in the right direction
A man will pay $2 for a $1 item he needs.
A woman will pay $1 for a $2 item that she doesn't need but it's on sale.
Exdecuk is offline
post #8 of 9 Old 04-28-2013, 04:44 PM
x10radsponge
x10radsponge is offline
post #9 of 9 Old 04-28-2013, 05:40 PM
Exdecuk
Originally Posted by x10radsponge View Post
yeah, my bad
Exdecuk is offline
