-   -   360 to 408 ? (http://www.jeepforum.com/forum/f13/360-408-a-1514622/)
SpenceAK 04-25-2013 06:34 PM
360 to 408 ?
Bout to pull my 5.9 for rebuild been looking at Hughes engines 408 stroker kit. my plans are for a high torque long mile engine. I'm buying new heads but staying with stock iron heads and rv cam
1. Will my stock computer work with a 408 or is there tuning required?
2. What would be good to upgrade in the valvetrain? Springs rockers......
Texas ZJ1 04-25-2013 06:44 PM
Email kolak from my SIG.
ratmonkey 04-25-2013 07:05 PM
rv cam won't be enough for that motor, nor will the "stock" heads. at a minimum you should be running the EQ iron ram 2.02's, the indy rhs x-heads would be a better choice. use a modified kegger intake, and i'd want at a minimum a 510/510 lift cam for it.
you'll need to get the b and g chrysler computer flash for it and at least 24# injectors. though i'd step up to at least 26# to keep the duty cycle lower and the horse power overhead higher.
don't half butt it. if you're building a torque monster motor, build a torque monster motor. get the pistons milled for a 10-10.5:1 compression ratio for some extra grunt. you're going to be needing premium anyways, may as well take full advantage of it.
SpenceAK 04-25-2013 07:21 PM
A thanks for the advice that's pretty much what I needed to know but I'm afraid that's probably out of my budget. I'd just figured while I got this 360 out maybe I should look into the stroker but still gonna crunch sone numbers. I still gotta lift this thing axle swap , rear gear well you know...
I will email kolak
SpenceAK 04-25-2013 07:24 PM
Oh and I should mention its not cheap to ship to Alaska!
SpenceAK 04-26-2013 08:39 AM
what are some good head upgrades for the 360?
Exdecuk 04-27-2013 03:58 PM
head on over to www.speedfreaks.com and they will point you in the right direction :2thumbsup:
x10radsponge 04-28-2013 04:44 PM
That is www.thespeedfreaks.net
Exdecuk 04-28-2013 05:40 PM
Originally Posted by x10radsponge (Post 15360453)
yeah, my bad :thumbsup:
The time now is 09:42 PM.
