#1 | |
35C Drain Plug
Ok I am changing my diff fluids and I have some questions. I found the drain plug on my Dana 30 (front axle) and I took it out and the oil is draining right now. So while that was going I went to the back axle (dana 35c) to find that there was no drain plug just a rubber cap. Am I supposed to remove that as a drain plug or do I have to take the whole cover off? Also if the drain plug is so high how does all the fluid drain out? This is on a 04 wj.
#2 |
yeah u just pop it off..
to drain the whole thing u should just remove the whole cover itll make things easier.. i need to do mine here in the next week or so
- John - 22 and learning <-- ORIGINAL -Black 96 ZJ Limited 5.2L V8 lifted 5" and blacked out with some fun stuff RIP Troy Edwards
#3 |
ok and how do I refill it? What sealant do I use then?
#4 |
That's not a drain plug, it's the fill plug (you fill it to the level of that hole).
You either need to drain it by removing the cover, or by using a hose/pump (~$5 at any parts store). Refill using that same pump/hose. |
#5 |
o yeah its a fill plug, my bad
just remove it, then u must reseal it, using a gasket and some RTV let it dry then fill with fluid thru the fill hole
#6 |
So you just fill it up until it starts to come out?
#7 |
4.0 Piston Skirt Victim
Yeah, tll it to the bottom of the hole.
WALTER |
#8 |
Mr. Hyde!
Yep.
Neither diff's have drain plugs. Pull the cover, inspect the fluid and magnet for metal shavings. Use some brake cleaner to clean out the inside and inspect the gears. If the gears look like my avatar, that is bad. Reseal with some RTV sealant (I prefer The Right Stuff sealant) and reinstall the cover (13-15ft/lbs on the bolts). Fill until it comes out of the cover.
'04 WJ, 6" Clayton LA's, 242 SYE, 35" BFG MT KM2's, 4.56 gears, & D44a locked |
#9 |
Arlo you are the man thanks for the help. I have to go ride my bike now to AutoBarn because that is the closest place. I will let you know how I make out...so much for going out on the boat today, o well maybe tomorrow.
#10 |
If I spray brake cleaner in there do I have to clean it out or just leave it in there? Also do I need to put anything like threadlocker on the cover bolts?
#11 |
Mr. Hyde!
It'll drain out for the most part, but it also evaporates very quickly. Use a clean rag to pull out the grunk at the bottom of the diff housing, then spray some (an entire can if you want) of brake cleaner in there and it'll drain out and pull some grunk with it. Give it a minute and it'll all be dry in there.
No need for thread lock.
#12 |
OK does it matter what rtv silicone I buy? I bought the Blue one which says senors safe but there was a red one that said high heat. The guy told me the blue would be fine I just dont trust him. What do you think?
#13 |
Mr. Hyde!
Probably doesn't matter...not sure which ones you bought since I have only used The Right Stuff sealant and the black sealant that comes with a gear master install kit.
#14 |
Seeing this is not good
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Claytons/JKS Control arms out back/Addco's/RE brake lines/35"TSL SSR's on 5.9rims/Currie steering/K&N/JKS rear trackbar/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/D30lockrite D44a |
#15 |
Mr. Hyde!
Cool, much worse then mine were
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
