33x10.5s without cutting metal? - JeepForum.com
post #1 of 16 Old 03-27-2014, 06:10 PM Thread Starter
MrSpooky
Hello, I am thinking about building up my ZJ but I am getting different views on fitting 33x10.5s with no trimming. I have no problem cutting the plastic bumpers but I do not want to start cutting on the body. Eventually I will get some off road bumpers with more clearance but I want to get it lifted with tires first. Is that possible with 3.5 or 4.5 to 5.5 inches of lift with proper bumpstops and 3.5-4 inches of backspacing on the wheels?
I have had the Jeep since new and the body is super straight and clean. I just cant bring myself to start cutting it up like I did my other Jeeps. Don't plan on crawling it, just using it as a camping, outdoor vehicle.
Thanks
Mike
MrSpooky is offline
post #2 of 16 Old 03-27-2014, 06:19 PM
WhiteOut
WhiteOut's Avatar
On a properly set up lift, you should be fine at about 4" of lift.
WhiteOut is offline
post #3 of 16 Old 03-27-2014, 06:24 PM
JasonStebbins
Proper bump stops will be the key factor. Light trails to campgrounds shouldn't stuff the tires way up there anyway so you should be good.
Poop
JasonStebbins is offline
post #4 of 16 Old 03-27-2014, 08:33 PM
jeeepguy
jeeepguy's Avatar
Use 31s instead and eliminate any issue at all.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #5 of 16 Old 03-27-2014, 08:57 PM
JasonStebbins
Pretty much the best idea unless you really want bigger tires. If you don't plan on wheeling very much a solid set of 31" A/Ts or M/Ts will work fine for your needs.
Poop
post #6 of 16 Old 03-27-2014, 08:59 PM
tucsonzj
you are aware that when you do flares you cut metal right?
but yes if you're that worried about it just do 31s
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #7 of 16 Old 03-27-2014, 09:10 PM
JasonStebbins
Who said anything about flares?
Poop
post #8 of 16 Old 03-27-2014, 09:12 PM
JohnnyZJ
33x10.50 is a great combo with 3.75" back space and a 3.5" lift. 31s are ghey.
you will need to hammer down the inner pinch seam on the inner fender. go look you will see a 1" piece of metal sticking out. hammer it flat. there is no worry with doing that. it won't hurt it. I would also trim the inner fender plastic pieces too
JohnnyZJ is offline
post #9 of 16 Old 03-28-2014, 11:07 AM
tucsonzj
You mean rip them out right?
Sent from AutoGuide.com Free App
tucsonzj is offline
post #10 of 16 Old 03-28-2014, 11:17 AM
PolkaPower
Rip out the pinch seam? Just hammer it flat and hit it with some black paint. Takes a few minutes on each side at the rear of the wheel well. You can rip the front plastic out no problem.
PolkaPower is offline
post #11 of 16 Old 03-28-2014, 12:42 PM
tucsonzj
i meant the plastic haha
fyi I just threw my 33x12.5 under my 3.5" lift. Planning on trimming and adjustable arms will be on their way when I sell of the old tires (for those who are about to bash me)
tucsonzj is offline
post #12 of 16 Old 03-28-2014, 01:12 PM
huntsducks70
just don't disco the front and you will be fine, when you disco is when you have to deal with stuffage
1998 Jeep Grand Cherokee Ltd
5.2L, 231 Swap, 3.5in RE Fr Coils, RE Shocks, Fr to Rr, Front HD Clayton T-Bar and Bracket, Custom Raised Rear TB Axle Mount w/Stock Bar, Cut and Rolled Front Fenders, 15x8 w/31x10.50
huntsducks70 is offline
post #13 of 16 Old 03-28-2014, 01:43 PM
PolkaPower
When I get another one I'm going to do what TimoXJ did and chop off the fenders and cut into the wheel well to make more room. I'll run as little lift as I need to get 35's under it.
post #14 of 16 Old 03-28-2014, 02:17 PM
tucsonzj
kinda my thought. lower lift with biggest tires...I need a welder! haha
tucsonzj is offline
post #15 of 16 Old 03-28-2014, 10:32 PM Thread Starter
MrSpooky
Thanks for all the help. I think I will go 3.5, hammer the pinch weld and ditch the plastic liners and 33x10.5s. If I need more lift I will use a 1 inch spacer and some adj arms, and adj track bars. Just personal opinion, but I don't want to spend money on a lift, and new tires for just 31s. I say I don't plan on crawling it but I seem to always find myself in the rocks, especially here in CO.
Thanks
Mike
MrSpooky is offline
