33" tires-What Axle? - Page 3 - JeepForum.com
post #31 of 77 Old 01-28-2013, 03:30 PM
JMSMN
A d44a with a BTF cover and a spartan regeared to 4.56. How much abuse can that handle? 33's and some abuse?
JMSMN is offline
post #32 of 77 Old 01-28-2013, 03:33 PM
PolkaPower
33's shouldn't be an issue. A trussed 44a could handle 35's max. Maybe bigger with some upgraded shafts. The tubes are the weak point.
PolkaPower is online now
post #33 of 77 Old 01-28-2013, 03:42 PM
JMSMN
It sucks that I already bought my iro 5.5" critical path long arm kit....for the lpd30. So a truss and sleeving axle tubes help? Can I buy arb carrier to upgrade to 30 spline shafts?
JMSMN is offline
post #34 of 77 Old 01-28-2013, 04:05 PM
KyBoy1991
I will trade ya my IRO lift/arms for yours and give ya $400....you won't have to worry about a thing then!
KyBoy1991 is offline
post #35 of 77 Old 01-28-2013, 04:07 PM
riot1987
Your problem isnt so much the axle strength on a d30. Once you get up to 35's or there about you start putting a lot of stress on ball/u joints. Axle sleeves wouldnt do anything for you in that department unfortunately
Build thread^^
riot1987 is offline
post #36 of 77 Old 01-28-2013, 04:21 PM
JMSMN
I probably will never go over 33" tires. With that in mind could it hold up?
JMSMN is offline
post #37 of 77 Old 01-28-2013, 04:31 PM
riot1987
yup. seen it dozens of times. Just dont drive like a ******* and that d30 will last awhile.
Build thread^^
riot1987 is offline
post #38 of 77 Old 01-28-2013, 06:05 PM
JMSMN
Well I just had a conversation with IRO. They are willing to take back my iron y for the lpd30 in exchange for high pinion one. My next question is the hpd30 up to the task of 35" tires. Truss, weld in axle tubes, weld in axle sleeves and 30 spline upgrade.
JMSMN is offline
post #39 of 77 Old 01-28-2013, 06:12 PM
kg6mov
Hears the voices
kg6mov's Avatar
dig up a d44 from a waggy or something if you're gonna replace the front axle.
kg6mov is online now
post #40 of 77 Old 01-28-2013, 06:26 PM
JMSMN
Is it the same width?
JMSMN is offline
post #41 of 77 Old 01-28-2013, 10:02 PM
riot1987
You can run an hp 30 semi comfortably with 35's. Thats what Im putting in mine this summer. Its the cheapest and easiest route.
Build thread^^
riot1987 is offline
post #42 of 77 Old 01-28-2013, 11:36 PM
JMSMN
Originally Posted by riot1987 View Post
You can run a n hp 30 semi comfortably with 35's. Thats what Im putting in mine this summer. Its the cheapest and easiest route.
What year should I be specifically looking for? Without vaccuum disconnect? Abs issues? Same width too?
JMSMN is offline
post #43 of 77 Old 01-29-2013, 05:18 AM
Mark-318-IT
hi guys, and what do you think about swapping some D44 from a JK?
Mark-318-IT is offline
post #44 of 77 Old 01-29-2013, 07:26 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Are the stockers broken? Did you re gear them? Do you have the 33s on?
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #45 of 77 Old 01-29-2013, 08:47 AM
riot1987
Im rebuilding an 88 out of an XJ. It has a Vac disco that im gonna bypass. I no longer have ABS so im not sure on that one. Yes width is good.
Build thread^^
riot1987 is offline
axle
