31s with just a BB?? - JeepForum.com
post #1 of 13 Old 02-18-2003, 03:19 PM Thread Starter
Kess
could i fit 31s on a 94 zj, with just a BB, maybe upgrade shocks too??thanks
In comission:2004 WJ, stock....
Retired:1994 JGC Laredo I6 4.0L, Smittybilt Outland brush guard, 1 3/4" Daystar coil spacers, custom air intake with tube K&N, Borla cat-back, KC Daylighters 6" 150w stainless steel, Xenon superwhite headlights 85/100w, 235/75/15 Pirelli Scorpian A/T, billit aluminum grill inserts
Kess is offline
post #2 of 13 Old 02-18-2003, 05:00 PM
TOM380
You can fit them but you will have to do a little trimming. I had 31's on mine with a BB and they rubbed a bit. I now have 30's and no rub even when I'm offroading. That is the real test they may not rub on the pavement but when you're offroad they will. I sacraficed looks for performance. Although I will be going to a higher lift in the future and 31's will be installed.
1997 ZJ 5.2L V8,K&N AIR FILTER,FLO-MASTER EXHAUST 2"BB LIFT 30" REMINGTON WIDE BRUTES. ProComp ES3000 SHOCKS, CUSTOM SPARE TIRE CARRIER AND ROOF RACK,HELLA LIGHTS. JUST GETTING STARTED!!!!!
1968 Jeep (Kaiser) Wagoneer, Buick 350 V8, Isky cam,HEI ignition, TH400 trans and completly stock inside and out.
TOM380 is offline
post #3 of 13 Old 02-18-2003, 06:39 PM Thread Starter
Kess
did the rubbing occur at full flex or turning or what?? i dont do a whole lot of offroading esp right now i dont have my baby, bloody university rules......
Kess is offline
post #4 of 13 Old 02-19-2003, 08:23 AM
Howler
Kess, if you want lots of flex then I would go with 30's on a BB. The 31's I would considfer more for show to mild off-roading. They do fit but it also depends on the brand. ie. BGF 31's measure 30.5 I think where teh swampers would be 31.5. Or something like that.
Howler
97ZJ 5.2L with 5" lift. 31" SuperSwampers TSL
To boldly go were no Grand has gone before.
Howler is offline
post #5 of 13 Old 02-19-2003, 09:52 AM Thread Starter
Kess
i was looking more for mild offraoding and just the fact of having 31s.... ....i either wanna get bf m/ts, or procrap m/t, ne suggs??
Kess is offline
post #6 of 13 Old 02-19-2003, 12:31 PM
Cajunzj
Cajunzj's Avatar
If you cut your bumper in half, it will give you no problems, or you could just cut the bottom front corner ( you'll see when you put them on). As for the LCA's you can fix really easliy. Once you got the tires on undo the steering stop bolt, put about 2 washers on it then put it back on. Don't worry, you'll barely notices the diff. But that will keep you from turning your tires into the LCA's. As for the flex, just go to Home Depot and make some disco's, for the front. I ran this setup for about 7months and did great. good luck
04 WJ lifted and stuff
79 CJ7 project jeep
Cajunzj is offline
post #7 of 13 Old 02-19-2003, 01:24 PM
TOM380
What do you mean Home Depot for Disco's? I keep seeing people writing about Discos. What is it and what does it do? I am guessing it disconnects something on the suspension?
TOM380 is offline
post #8 of 13 Old 02-20-2003, 08:03 AM
Howler
Disco's or Disconnects are attached to the sway bar so that when ou off-road you can disconnect your sway bar to allow your axle to droop and float. When you lift your vehicle you need to have disconnects because the sway bar is now that much further away from the axle. However at 2" BB I personally don't think you need them. I still run stock swaybar links at my height but I do not have a rear sway bar anymore.
Here is Rubicons page of sway bar disconnects foryou
http://www.rubiconexpress.com/dynami...p?Folderid=235
Howler is offline
post #9 of 13 Old 02-20-2003, 11:32 AM
Cajunzj
Cajunzj's Avatar
Don't get the RE disco's yet, your just getting started, save the money. Go to home depot/lowes whatever and get 2 pins with the holes all down the side and 2 cotter pins. Take out the orginal swaybar bolts (star bolts) and put the new ones in and slide the cotter pin through. done.
Some one needs to jump in on this, my post is kinda vauge.
This is by far the easyiest and one of the best mods you can do when starting out. 5$ and 30 min. easy
79 CJ7 project jeep
Cajunzj is offline
post #10 of 13 Old 02-20-2003, 12:24 PM
Howler
Here he means this.
http://www.rockcrawler.com/techrepor...ects/index.htm
Sorry forgot to add to get 1/2' washers to put on the side of the pin so it does not wear down in time.
Howler
Howler is offline
post #11 of 13 Old 02-20-2003, 08:26 PM
jboswish23
so will 31x10.50 tsl's fit with a 1.75 daystar coil spacers
jboswish23 is offline
post #12 of 13 Old 02-21-2003, 05:01 PM
TOM380
Yes they will fit but you will be limited in clearance for any mid to heavy offroading.
TOM380 is offline
post #13 of 13 Old 02-21-2003, 05:05 PM
TOM380
Thanks to everyone for the info. It is really appreciated
TOM380 is offline
