31 inch tires on stock ZJ??? - JeepForum.com
post #1 of 10 Old 06-24-2011, 10:19 PM Thread Starter
89XJ250
1989 XJ Cherokee
Is it possible with some trimming to fit 31 inch tires on 15 inch wheels on a stock ZJ. It is a 1993 jeep grand cherokee?
89XJ250 is offline
post #2 of 10 Old 06-24-2011, 10:25 PM
LilyBayXJ
Depending on the amount of trimming you want to do, you could fit 40's if you wanted. I fit 31's on my XJ stock, and it was a tight fit, and I know ZJ's are even tighter. But with the right amount of trimming, they should fit no problem.
2006 LJ - 4.0L, NSG370, 31's
2001 XJ - 4.0L, AW4, 3.5" lift, 31's
1997 TJ - 2.5L, AX5, 2.5" lift, 32's - Sold
1983 CJ-5 - Stock - Sold
LilyBayXJ is offline
post #3 of 10 Old 06-24-2011, 10:28 PM
TallyZJ
They will rub some where. You need at least 2" to run 31's with no rubbing and even then you may rub the control arms on full turns.
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
TallyZJ is offline
post #4 of 10 Old 06-24-2011, 10:29 PM
khakioutlaw
Yes, with a minor trimming to the front bumper, you can get 31's to fit your ZJ.
khakioutlaw is offline
post #5 of 10 Old 06-24-2011, 10:50 PM
rooster51
pot holes and bumps while make your rear fender grind the tires
Terry
rooster51 is offline
post #6 of 10 Old 06-25-2011, 12:29 AM
zjzach
4.5'' backspacing and minor trimming on your front bumper cover.
but yea hit a pothole or dip in the road at any speed and you'll hear em. count off roading out till you can get 2'' or 3.5'' under it.
my build/wheelin/picture thread
zjzach is offline
post #7 of 10 Old 06-25-2011, 10:38 AM
Trimble96ZJ
Just took the front bumber off.
Trimble96ZJ is offline
post #8 of 10 Old 05-11-2013, 12:37 AM
zjfamilyman
With Up country sort of
My 97 has up country suspension and after a bumper trim it only rubs the control arms at full lock not even when parking, but you end up doing more three point turns off road. Mine doesn't rub in the bumps but I'm looking into getting a 2" lift to clear it properly.
Every mountain is unclimbable until it is climbed, every ship unsinkable until it is sunk.
zjfamilyman is offline
post #9 of 10 Old 05-11-2013, 12:42 AM
zjfamilyman
Also with up country suspension (because I was wondering this before) I didn't get any rubbing on the bumper while going forward, only in reverse and then it was slight. (Not sure why that is). For those that don't know Up Country suspension is essentially a one inch lift from the factory with higher quality components. Technically stock but it is important to know what you've got.
post #10 of 10 Old 05-12-2013, 08:12 PM
StevieB76
I have 31x10.5x15s on my 95 ZJ Orvis w/ upcountry suspension and stock Orvis wheels...little rub on sway bar at full turn and slight rub on in rear wheel wells at full stuff...nothing I can't live with though....31s on a non upcountry equipment ZJ may be a whole nother story without at least a BB, thinking about doing a BB on mine as it is for a little extra clearance....pic of mine on 31s north of Vegas
StevieB76 is offline
Stock WJ on 245/75/16 and 4 inch BS, ok? northpaw ZJ Grand Cherokee Forum 15 09-03-2009 08:55 PM
running one 12 inch sub with a stock amp? 318jeepcherokee ZJ Grand Cherokee Forum 3 09-04-2008 07:04 AM
Ideal tire pressure for stock GC w/ stock tires? Black Hole ZJ Grand Cherokee Forum 9 01-31-2007 12:49 PM
What Do You Think.... 2 Inch? Tires? bownw ZJ Grand Cherokee Forum 7 03-03-2005 04:29 PM
Help with a tire decision, 31 inch possible on a stock ZJ? spankey ZJ Grand Cherokee Forum 8 10-20-2004 02:09 PM
