30k mile service for 4.0L I6 - JeepForum.com
post #1 of 10 Old 10-13-2005, 09:37 PM Thread Starter
JCDubya
2009 WK
I'm about due for my 30K mile service. I have a couple questions. One of the things listed is tranny fluid change, internal filter, and adjust bands. Is it hard to "adjust the bands"?
It also lists spark plugs, should I just go with mopar, or aftermarket?
JCDubya is offline
post #2 of 10 Old 10-15-2005, 11:41 PM Thread Starter
JCDubya
2009 WK
nobody?
JCDubya is offline
post #3 of 10 Old 10-16-2005, 02:52 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
As far as spark plugs go I use the recommended Champions, but I generaly don't change mine until about 70,000.
I can't tell you anything about the trans adjustment as I have never tried it. I took mine to the dealer for the trans service.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #4 of 10 Old 10-16-2005, 08:06 AM
Woody
Retired back to Bowties
Woody's Avatar
1985
Band adjustment is not hard. Get a Haynes manual and it details all you need to know. If you do it yourself you will need a Torque wrench. I mention that because everything else isn't all that abnormal, but the torque wrench isn't something everyone has.
At 30K I would change the fluids in both differentials as well. For plugs, and we had a thread on this a few months back. I recommend Champion truck plugs. They are not platinum, but they are heavy duty and work great in all vehicles I've run them in. Don't do the multi-tip things, they don't make a noticable difference and cost a lot.
Sorry I didn't post earlier, I overlooked it.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #5 of 10 Old 10-16-2005, 08:53 AM Thread Starter
JCDubya
2009 WK
I checked my FSM CD, (why do I always forget about that thing?). It doesn't seem hard at all. Basically just torque it down to spec, then back it off X amount of turns? I just wasn't sure if it was harder or more involved than it seemed. I do have a torque wrench, Craftsman Digitork, and it sure got a workout yesterday!
It looks as though the 4.0L oil pan gasket is reusable. Is this the case, or should I put a new one on anyway? To drop the pan, does anything else have to be removed first? I keep forgetting to take notice when I'm under the thing...
For the spark plugs, it looks like NGKs are what's in it now. Should I just keep using those? Here
JCDubya is offline
post #6 of 10 Old 10-16-2005, 09:24 AM
ksgrands
2004 maybe doesn't need band adjustments, my 2000 doesn't, according to Haynes. I've reused the mopar gaskets, I know they work. Yours may not have come with one from the factory. Mine had the cork, but use the reusable, saves alot of scraping. Again, I'm basing this on my 2000. Please do yourself a favor and keep up with the tranny fluid intervals, they really like the fluid changes.
97ZJ
00WJ-Sold
90 Comanche Pioneer 4x4, 3inches, 31's SOLD
89 Comanche Pioneer 2wd
97 Wrangler Sport
ksgrands is offline
post #7 of 10 Old 10-16-2005, 09:24 AM
Woody
Woody's Avatar
1985
Don't reuse gaskets. Bad idea altogether. Don't pull the oil pan either otherwise you'll be doing more work than you have to. Pull the transmission pan instead. This is very messy. When you buy the tranny filter the gasket should be included with the kit.
If your plugs need changing, I'd go with the truck plugs. But that's just me.
Woody
Woody is offline
post #8 of 10 Old 10-16-2005, 09:34 AM
ksgrands
The Mopar gasket is separate and thats what I recommend(not cork). By the way I highly recommend Mopar fluid. Too many questions about compatibility with the others. I spent about $50 at my dealer for 6 qts fluid, filter and reusable gasket. I know everyone wants to save, but this is one area I think it's money well spent. And I just assumed he meant the tranny oil pan,(Ihope).
97ZJ
00WJ-Sold
97 Wrangler Sport
ksgrands is offline
post #9 of 10 Old 10-16-2005, 09:38 AM Thread Starter
JCDubya
2009 WK
Yes, that's what I meant. I'm still getting used to this whole automatic thing
just an FYI, my 2004 FSM recommends the tranny bands be adjusted every 30K miles. I just had my tranny rebuilt at 20K, so I'll probably wait another 10K before I do the tranny service.
JCDubya is offline
post #10 of 10 Old 10-16-2005, 11:18 AM
ksgrands
I need to get one of those FSM's.
97ZJ
00WJ-Sold
97 Wrangler Sport
ksgrands is offline
46k km or 30k mile service afss WK Grand Cherokee & XK Commander Forum 4 12-07-2009 03:43 PM
What should I do in the 60,000 mile service? tivoboy ZJ Grand Cherokee Forum 13 07-21-2009 08:13 PM
30K Mile Service Question (Dealer to do service) Natemare13 WK Grand Cherokee & XK Commander Forum 3 03-24-2009 11:52 AM
60,000 mile service? ashy22 ZJ Grand Cherokee Forum 32 09-25-2007 12:38 PM
30k mile service? onrails ZJ Grand Cherokee Forum 3 02-12-2006 08:20 PM
