30-40mph Shake...I don't think its DW. - JeepForum.com
post #1 of 6 Old 04-03-2009, 02:36 PM Thread Starter
Smith Erick
Smith Erick's Avatar
I know what death wobble is. I had it on my old 95 ZJ that wasn't lifted.
I know have a 04' WJ (setup is in my sig.) I experience crucial vibrations/shakes at 30-40mph. Streering wheel left to right.
If it gets bad enough it does develop into death wobble, but it doesn't seem the exact same.
Car doesn't shake at low speeds nor at highway speeds.
This was a problem for a while, I just replaced the rotors for stillens and added a JKS trackbar, the jeep feels more solid but still has the shake at 30-40.
Any ideas?
"Smith Erick"
2004 Jeep Grand Cherokee Special Edition--4.7L V8
15% Tint, Front Tow Hooks, Skid Plates
Yakima Towers and Bars
Uniden Pro510 CB with taillight mounted 3ft. Fire Stik Antenna
Full Aftermarket Infinity Speakers w/ JL 10W7
Kevin's Round Bar Rock Sliderz powdercoated Black
Kevins 2.5 BB w/ Procomp MX-6 shocks
JKS Quicker Disconnects
OME SS
Addco Rear Sway Bar w/ Energy Bushings
TransGo Shift Kit
Kolak Exhaust
15in Crager Streetlocks
31"x10.5" Firestone Destination M/T's
Smith Erick is offline
post #2 of 6 Old 04-03-2009, 02:37 PM
Bort62
Pretty much sounds like DW. Mine is doing the exact same thing - I've got a new SS and TRE's on the way to fix it.
___________
'98 Grand
'60 Ranchero
Bort62 is offline
post #3 of 6 Old 04-03-2009, 03:32 PM
jeep_zj98
2012 WK
Check the balance on the wheels. Mine used to shake the steering at 45-50 mph range. I moved the front tires to rear and the shake was gone. That told me that the wheels were out of balance. Total cost to me: $0.
jeep_zj98 is offline
post #4 of 6 Old 04-03-2009, 03:42 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
make sure your trackbar is bubba tight.
ratmonkey is offline
post #5 of 6 Old 04-03-2009, 04:05 PM
hike4it
check this
http://www.jeepforum.com/forum/f13/soft-8-s-mini-death-woble-739064/
And if you still have your stock wheels put them on and see if you still get it
hike4it is offline
post #6 of 6 Old 04-03-2009, 10:10 PM
cloiselle
check the inner circumference or you WHEELS for mud and debris that could be throwing your wheels off balance, also spend $20 and get them balanced and rotated.
that is the first step i would take.
after that check your track bar and other fastening bolts up front.
if it still continues i'd suggest a steering stabilizer but i have a feeling you will not need to go that far.
after a good session in the dirt my entire wj shakes like mad from debris unbalancing the wheels, i now keep a small putty scraper in my hatch to clean them out before i even leave the trails.
good luck !
cloiselle is offline
40mph feels like I'm going over small bumps.. BlueTJMCRT WK Grand Cherokee & XK Commander Forum 8 01-15-2011 09:10 AM
97 zj DW when above 40mph and brakiing diving me nutss! lol GrandZjs ZJ Grand Cherokee Forum 3 06-19-2009 11:45 PM
vibs at 40mph+ OFFCHAMBERXJ ZJ Grand Cherokee Forum 5 01-06-2007 02:26 PM
Slight Shudder around 40mph IMFLASH WK Grand Cherokee & XK Commander Forum 5 11-19-2006 05:10 PM
Sputtering while Driving at 40mph jeeplovr ZJ Grand Cherokee Forum 10 12-19-2005 05:45 AM
