3 questions, help! 1994 ZJ - JeepForum.com
post #1 of 4 Old 01-09-2005, 07:52 PM Thread Starter
haywood
I have a 1994 ZJ that makes a popping noise that seems to come from the middle of the vehicle almost everytime I brake or accelerate hard. I was wondering what could be making this noise. How do I fix it
My second question is what could be making the carpet in the back of the car wet, and how could I fix it.
One more question. My steering wheel is always turned part way right when I am going straight. Is this my steering stabilizer? how do I fix.
haywood is offline
post #2 of 4 Old 01-09-2005, 08:01 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
First question:
You could have a worn ujoint at the front or rear driveshaft.
Second:
quit scaring the pee out of people when you drive! Probably a clogged rain drain hole or a leak in the roof.
Third:
you can adjust the steering wheel but it is more complicated than I want to get into for me on here. I'd grab a Haynes or Chilton's manual and dive into it.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 4 Old 01-09-2005, 08:19 PM
jeepholic
jeepholic's Avatar
Third question:
Loosen the two 15 mm bolts on the draglink that goes from the pitman arm to the tie rod, it has a sleeve you can spin and center the steering wheel, make sure the jeep steering is unlocked. This will not affect alignment.
I use a Jeep
You drive a car
Big difference.
94 I6 ZJ at 4", 33's and front locker and 4.11 gears. Swampy Bypass.
Black Jeep Club Member Ver. 2 #51
jeepholic is offline
post #4 of 4 Old 01-10-2005, 08:30 AM
jeepholic
jeepholic's Avatar
This is a pic of the draglink that is connected to the pIttman arm, you can see the 2 bolts that need to get loosened and then you spin the sleeve, with the wheel unlocked to center it.
I use a Jeep
You drive a car
Big difference.
1994 ZJ lift questions prplhz96 ZJ Grand Cherokee Forum 28 06-05-2013 01:03 AM
Which FSM to get for 1994 ZJ KN94ZJ ZJ Grand Cherokee Forum 2 03-31-2009 05:38 PM
4.0 to 5.2 zj 1994 bakke ZJ Grand Cherokee Forum 1 11-20-2006 02:49 PM
1994 ZJ - Tune Up Questions Blacula ZJ Grand Cherokee Forum 8 03-22-2006 11:35 AM
Up Counrty + 1994 ZJ seanounorman ZJ Grand Cherokee Forum 3 07-29-2005 06:53 PM
