3" coil spacer? - JeepForum.com
post #1 of 7 Old 01-12-2014, 04:25 PM Thread Starter
chiefjohnston
3" coil spacer?
Is it necessary to relocate track bar with a 3" coil spacer BB?
chiefjohnston is offline
post #2 of 7 Old 01-12-2014, 04:48 PM
Sourlemon
Yes otherwise your axles are not centered. 2" is the largest you can go without getting adjustable ones.
96 ZJ limited 2" BB 245/75/16 Kenda Klevers, 200k+ miles, Winch Bumper, Aux Lights
MOPARCAP trained
Sourlemon is offline
post #3 of 7 Old 01-12-2014, 06:42 PM
riot1987
I drove around on 3" w/o them but, I wouldnt suggest it. Ideally you should have em at 3"
Build thread^^
riot1987 is offline
post #4 of 7 Old 01-12-2014, 09:30 PM
JasonStebbins
Most people don't go over a 2.25" spacer anyway. If you're going 3" or higher I would recommend springs. At that height you will need more parts anyway so you're better off getting a small lift kit or a regular sized budget boost.
Poop
JasonStebbins is offline
post #5 of 7 Old 01-12-2014, 09:49 PM
jeeepguy
jeeepguy's Avatar
  1. Don't do a 3" BB... its a bad idea. Just because you can doesn't mean you should. Above 2", get a real lift
  2. You will need to have the axle recentered on any lift of that size or above and the only way to do that is via an adjustable trackbar
  3. Don't use relocation brackets on the rear trackbar. Another bad idea
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #6 of 7 Old 01-14-2014, 02:22 PM
tucsonzj
Originally Posted by jeeepguy View Post
[*]Don't do a 3" BB... its a bad idea. Just because you can doesn't mean you should. Above 2", get a real lift
[*]You will need to have the axle recentered on any lift of that size or above and the only way to do that is via an adjustable trackbar
[*]Don't use relocation brackets on the rear trackbar. Another bad idea
These
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #7 of 7 Old 01-15-2014, 01:31 PM
Jeep_zj93
1994 ZJ
its fine to run a rear track bar bracket as long as its the right one. Stay away from the ones that bolt to the rear axle, they are junk and rip off. If you do get one then get the style that bolts up to the unibody side and you will be fine, Iv run them for years with no problems.
Jeep_zj93 is offline
