3.5" iro kit with 32s rubbing on rocker at half turn - JeepForum.com
post #1 of 14 Old 02-18-2009, 06:14 PM Thread Starter
patcam
hey was told about this website couple months ago and did lots of reading...blah blah blah. I installed the IRO 3.5 F>R kit plus new rear adj tb new stering stabilizer and 32X11.50 goodyear Wrangler MTRs, my problem is the tires are rubbing on the rocker panel right behind the front wheels after turning wheel 180* either way. I was told i would have to trim bumper? yet tires are not even close:s Ride is awesome no dw or anything really my only problem. Looking for suggestions like new lower adj control arms or something but would'nt that throw my caster off .. is my only choice buying all new front adj. cas? any replies are appreciated will post pics of zj and rubbing tomorow, thanks
patcam is offline
post #2 of 14 Old 02-18-2009, 06:31 PM
BLACKzj52
lca's would help
other would suggest just trimming a little sheet metal off the back of ur front fender. if ur up to that then by all means go for it
either that or u can just avoid turning all the way
BLACKzj52 is offline
post #3 of 14 Old 02-18-2009, 06:40 PM
allenjp
Backspacing?
This is my JEEP. There are many like it but this one is mine...
1996 ZJ 318 Laredo Quadra Trac -SOLD (I'm gonna miss her!)
2002 WJ 4.7 Limited Quadra Drive (sharing it with wifey for now...)
allenjp is offline
post #4 of 14 Old 02-18-2009, 06:51 PM
BLACKzj52
^^i didnt even think about that.
OP do you have the stock rims?
post #5 of 14 Old 02-18-2009, 06:59 PM
311LJ
311Popo
311LJ's Avatar
it'd help if you could post some pics of everything ...
John
04 TJ Unlimited, GenRight Armor, 37's
89 XJ Laredo, 31's
07 WK Overland, Hemi, Chrome bug deflector
[SOLD] Jimmer 01 WJ *2009 GCOTY*
I ♡ John
311LJ is offline
post #6 of 14 Old 02-18-2009, 07:01 PM
DothanJeep
Yup...
00' WJ 4'' IRO 285 Tire...Ect-SOLD 7/2/2009
98' ZJ STORM TROOPIN' SOLD
97' ZJ with 117K THE DD mi SOLD
01'WJ Project Cheap fix.
DothanJeep is offline
post #7 of 14 Old 02-18-2009, 08:27 PM
melloyello
Those tires should rub in more than one spot. Are you flexing it? Disco'd or no? For mallcrawlin you shouldn't have much of a problem except for what you speak of.
melloyello is offline
post #8 of 14 Old 02-18-2009, 08:42 PM Thread Starter
patcam
re
As for the backspacing its 4" ive got 15x8 steelies not soft 8s ... its rubbing while on flat gravel links connected. As for the trimming i have trimmed a bit but its not rubbing on the fender its on the front side of rocker, very limmited trimming without having to cut rocker corner out and fabbing new piece, lots of bodywork which i hate etc..at that point ill just get new control arms and push wheels 1\2 " ahead or whatever space i need, just curious if anyone is running this setup and have some input..i will post pics up so u can see what im talking about...every search comes up with posts such as: " Will so and so tire fit with so and so lift". thanks for the info so far
patcam is offline
post #9 of 14 Old 02-18-2009, 08:53 PM
BLACKzj52
have you hammered the pinch seam flat?
oh btw, im impressed you were able to learn all this without ever making a post. good for you
post #10 of 14 Old 02-18-2009, 09:10 PM
UTChavok
Just get new lower CAs, youll be fine without uppers. Your ride will improve aswell.
-Ronnie
UTChavok is offline
post #11 of 14 Old 02-18-2009, 09:32 PM Thread Starter
patcam
re
I cut the seam off and ground it down flat with the fender. Id like to take credit for learning all this in a matter of weeks but im a liscense mecanic blessed with unlimited access to shop with hoist , torches welder etc.. which helps..thanks tho.
So new lowers it is.. should i get uppers too? Im conserned about pinion angle but if its been done ill give it a shot and go from there
thanks again for the info
patcam is offline
post #12 of 14 Old 02-18-2009, 10:20 PM
UTChavok
Im running just over 4.5" with stock uppers and im fine. Everyones heep is different though but you should be perfectly fine with only lowers.
-Ronnie
UTChavok is offline
post #13 of 14 Old 03-11-2009, 12:12 PM
scarthearmada6
i just did this lift myself and i havent had a problem untill i get to almost full turn and its just barely rubbing. and im running 33/1250s.
96 ZJ Laredo
99 WJ limited 4.7 quadradrive
06 WK 4.7 fully loaded Laredo awd/4lo
Nightcrew - 161
scarthearmada6 is offline
post #14 of 14 Old 03-11-2009, 03:34 PM
horatio102
I've got 6.5" of lift on my WJ and with 33x12.5 on 4" backspaced Soft 8s I had to grab the sawz-all before leaving the garage. I'm going to be flexing it out with the jack to check and see how much more cutting I need to do, and see about relocating my bump stops as well.
horatio102 is offline
Steering wheel takes half turn to move wheels...? aaron7 ZJ Grand Cherokee Forum 14 11-18-2007 08:19 PM
issues with the lift,.."rubbing" coyote runner WK Grand Cherokee & XK Commander Forum 6 10-24-2007 07:28 PM
Tire fitment question - "minor rubbing"??? DS1111 ZJ Grand Cherokee Forum 5 01-05-2007 07:20 PM
Tires on ~2"--rubbing & MPG--and BB pic request John in MA ZJ Grand Cherokee Forum 5 06-12-2006 12:29 PM
rubbing w/2"bb ? cherokee man ZJ Grand Cherokee Forum 8 09-23-2005 06:41 AM
