3.5 F>R swap now rear sag - JeepForum.com
post #1 of 24 Old 04-23-2010, 03:40 PM Thread Starter
zjdamien
1977 J-Series Truck
did the F>R spring swap now ive got a little sag in the rear and if i put anything in the back it sags alot more would some front springs from a V8 zj help or do i just need to by some new rear 3.5 springs
zjdamien is offline
post #2 of 24 Old 04-23-2010, 03:42 PM
kwellzz
I have same issue
Denver Motorcycle Repair
kwellzz is offline
post #3 of 24 Old 04-23-2010, 04:03 PM
MurdaJs
My v8 springs sit over 4" in the rear
MurdaJs is offline
post #4 of 24 Old 04-23-2010, 04:03 PM
ZJJay
ZJJay's Avatar
That sounds weird that your ZJ was basically level (I presume), then by swapping the springs the rear is now lower. I've weighed my 4.0 ZJ at work and with a full tank of gas plus 100# in the rear, the front came in at 2,220 pounds, the rear was 2,050, and total weight was 4,360. (I know the totals don't add up.) I would expect that springs designed for the front would be stiffer to handle the constant extra weight. But then, maybe since the front weight is relatively constant, maybe the rears are a little stiffer to handle the occasional extra loads. I don't know.
Is your front end higher after the spring swap? Or does it ride stiffer?
I don't remember how much lift the ZJ V8 front springs would give the rear, but I'm sure it wasn't 3.5 inches. I think it was somewhere between 1.5" and 2". Why don't you just reinstall your springs in the original locations?
Jay
'96 ZJ, 4.0L, 42RE, NP242, stock D30 and D35-LS w/ 3.73, 4-1/2" lift, 32" BFG ATs, Magnaflow, JKS track bars and disconnects, spare tire carrier, Optima red top, ROLA roof rack, KC SlimLite driving lights, CB and Yaesu ham radios, GPS
ZJJay is offline
post #5 of 24 Old 04-23-2010, 04:06 PM
MurdaJs
Jay
the IRO Front to Rear swap is based on the front springs giving 3.5 inches of lift in the rear, v8 springs net more
MurdaJs is offline
post #6 of 24 Old 04-23-2010, 04:11 PM
spife7980
yes his rear is higher, they are sagged from the 3.5" he was trying to get but i6 coils will net you around 3". and the fact that they are 17 years old doesnt help too much either.
and yes, v8 coils will give you 3.5", im on my 3.5" coils as we speak. go to a junkyard and grab a set of the v8, maybe even the upcountry v8 if you can find a pair. theres a reason that youre supposed to use the v8 in the first place. sure some have success with their i6 but most need a v8 coil.
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adj SA and TB, JKS Quick Discos, Bilstein 5125, 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid, Carolina Drive shaft, IRO exhaust
spife7980 is offline
post #7 of 24 Old 04-23-2010, 04:13 PM
BlackbeastZJ
I believe that it was intended to use the springs from a V8 ZJ. And from what I see most often from those with the I6, thats what they use, however mine sits perfect with the stock I6 springs, and thats with 100 pounds in the back. I think it just varies some from vehicle to vehicle.
But to the original poster, if yours is sagging with the stock springs, I'd recommend upgrading to the V8 ones, it'll be quite a bit cheaper than getting the 3.5 springs from IRO.
Did yours happen to come with the UpCountry package?
Sam-20: I love camo duct tape!
1995 Jeep Grand Cherokee Limited, blacked out
4.0 I6, NP249, D30-D35 with 3.73 gears
LED Interior and gauge lights, Silverstar Ultra's
Tinted tails, Baja fogs, Bedlined bumpers, removed cladding
Iron Rock Offroad 3.5" lift, 15x8 Cragar D Windows, 32" BFG A/T's
Curt trailer hitch, Cobra CB with 4ft RS antenna
Black Jeep Society
Christian Jeep Owners #37
BlackbeastZJ is offline
post #8 of 24 Old 04-23-2010, 04:16 PM
MurdaJs
Not that I know of, no decals or special shocks. I never measured it stock, but I was able to fit 31" GY A/ts with minimal rubbing.
MurdaJs is offline
post #9 of 24 Old 04-23-2010, 04:28 PM
jfabian
did a Rough Country F>R lift and mine sits level. like spife said, old *** springs can sag, and from what i have read all over the place, no two jeeps are the same. my .02
'93 Jeep Grand Cherokee Limited 4.0L, AW4 trans, NP 249 TC, D30/D35 F&R, 3.55 gears, 3.5 inch Rough Country lift, 31/10.5/15 BF Goodrich A/T, 15x8 Rock Crawler black steelies
jfabian is offline
post #10 of 24 Old 04-23-2010, 07:39 PM
rooster51
Negative. I just installed v8 front springs in the rear last weekend. I got 3 3/4" pass.side, & 3 1/2" dr. side. With a large wooden cargo toolbox and a good amount of gear.
Terry
rooster51 is offline
post #11 of 24 Old 04-23-2010, 09:03 PM
tbick
I got an extra set of BDS 2 in rear springs that gave closer to 3 or 4 in St louis. $65 for the pair plus shipping(actual). Will have 4in RC rears that will go for $65 plus shipping in a couple of weeks. And a set of V8 springs that would go for $20 plus shipping. Already got my 7in springs, just waiting to pass state inspection before I make the change. IRO Group buy is providing me with the Long CA for the front. Just PM me. If you are close Id meet you to save shipping. All springs are ZJ
"When in doubt, floor it out!!!"
94 ZJ 5.2 Stock and partially wrecked, will be a new project or sell for upgrades
98 ZJ 4.0 4 inch Rough Country + 2 inch bb and 34 x 10.50 and a lot more
99 XJ 4.0 2 door, V8 springs + 2 inch BB for 3.5 up front and bastard packed in back for 5 inches and 31 x 10.50
tbick is offline
post #12 of 24 Old 04-23-2010, 10:35 PM
JrMechanic
Does anyone have the spring rates for the V8 and I6 front springs? I'd be interested to know how much of a difference there is between the two, considering there's a very small difference in weight between the I6 and V8.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #13 of 24 Old 04-24-2010, 08:36 AM Thread Starter
zjdamien
1977 J-Series Truck
I've also got s home brew roof rack with a hi lift jack on it mounted on the rear both the rack and jack might be a extra 100-130 lbs. I found some springs that moog makes for the front of a v8 zj they are stock height but are progressive rate wonder what those would do??
zjdamien is offline
post #14 of 24 Old 04-24-2010, 01:00 PM
ISUzj
2005 WK
well i will put my in here, I have a V8 did a F<R Swap with rusty's 3" springs, My back is 1/2" lower than the front, there is some stuff in the back, but not much, the springs could just be getting soft. I got nearly 200K on the back springs and only 30 on the front.
Can't wait to get started, but my wallet can......
~~~_______oooo_
~~ / ../...\...\_____\
~~[_---_____---_\-\\\\\\-\
~~~(o) )-o---(o) )-o---) )
94ZJ 5.2 Red; Rusty's 3" Coils,Skyjacker hydro's, Brush Guard, Custom Rear Bumper, Custom Roof Rack, KVG Quick Discos, 31-10.50-15's DAYTON TIMBERLINE A/T OBA 2 Gallon tank
Can't buy it? BUILD IT!! Do it cheap too cuz your in college
ISUzj is offline
post #15 of 24 Old 04-24-2010, 01:34 PM Thread Starter
zjdamien
1977 J-Series Truck
Well I went to the gunk yard today to get some spring and ended up finding a 242 trans case instead didn't have the $$$ for both figured the t case was harder to find so I got it
zjdamien is offline
Rear end swap abe51 ZJ Grand Cherokee Forum 18 08-02-2009 11:32 AM
ZJ Rear Tailgate Swap 95JpZJ ZJ Grand Cherokee Forum 11 05-15-2008 04:39 PM
rear axel swap trailboy ZJ Grand Cherokee Forum 33 04-14-2008 10:06 PM
Rear hatch swap...96 onto a 94 rxl ZJ Grand Cherokee Forum 1 07-18-2007 10:02 AM
Rear end swap ?'s jeepman75 ZJ Grand Cherokee Forum 9 10-16-2006 10:50 AM
