Quantcast 3.1TD fuel injection pump/ veggie svo - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 3.1TD fuel injection pump/ veggie svo
Truck-Lite's New LED Headlamp SeriesCURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee!Poison Spyder DeFenders™ - "Tubeless" Jeep Fende
Old 05-20-2008, 01:52 AM   #1
colinc57
Hi
can anyone tell me what pump is used on the European 3.1Td Grand Cherokee (2000) - I think its a Bosch .. possibly VP37 ??
Anyone had experience of using SVO ( Straight Vegetable Oil ) in one of these - if so a what ( if any) adapations / %
colinc57 is offline   Reply With Quote
Old 05-20-2008, 02:09 AM   #2
jeep_on
I don’t know if the 3.1L TD came with the VP37, but I’m 99% sure the 2.8L CRD did. These are the same pumps the VW TDIs are running, so the pump is all right. Just check to see if it really is a VP37.
Why do you want to run SVO in your Grand any way? Why not go straight to BioDiesel. Saves a lot of fab work, as in adding two tanks, heat exchange and all of that crap. I know its easier to deal with once its installed, but SVO can cause engine problems. I run BioDiesel in my Dodge RAM, and its yet to have a problem.
2000 WJ Limited w/ 4.7L V8
1988 YJ Sahara w/ 4.2L I6
2006 Dodge RAM Laramie w/ 5.9L I6
Originally Posted by PM Thor View Post
Wait, you can't cross creeks up there? What the Hell is up with these Canadians?
jeep_on is offline   Reply With Quote
Old 05-20-2008, 03:23 AM   #3
colinc57
Do you make your own BioDisel?
I was looking to see if how it would run with single tank ... maybe just adding a heat exchanger
Old 05-20-2008, 07:17 AM   #4
colinc57
Out of interest - I tried to get info from dealer - unable to confirm actual unit make version BUT replecement cost £1784 ( $3500 !) unsure if that includes sales tax (VAT)
Old 05-20-2008, 07:51 AM   #5
merlinTec
Originally Posted by colinc57 View Post
Hi
Hi
Should say on the side of the pump, i Know it's a bosch pump but not sure on what system and I don't have one on site for me to go check. Premium quality diesel fuel with a minimum Cetane rating of 50 or higher is required going by the info I can find.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline   Reply With Quote
Old 05-20-2008, 09:17 AM   #6
colinc57
Hi
can't make out what the engraving says but having looked carefully/ at websites sure looks like the vp37 / EDC.. although of course feeding 5 injectors .. don't think this 3.1 5 cly was used elsewhere
merlintec... whereabouts are you ?.. in a dealership?
Old 05-20-2008, 09:49 AM   #7
gomes512
1994 ZJ
No don't use straight veg oil it will leave heavy deposits in the combustion chamber.
When you get your pump out check to see if it has rubber o-rings/gaskets. Some rubber types are biodiesel compatible but most are not. If not then it probably means that the rest of your fuel system isn't biodiesel compatible, in my experience, I would run a 20:80 mix of bio to diesel. Find out if your system is compatible, I hear that you can get conversion kits for some vehicles?
gomes512 is offline   Reply With Quote
Old 05-20-2008, 02:29 PM   #8
merlinTec
Hi
Hi
Yes in a dealership but I don't look here much more the WK forum.
Glock Forum
