2wd to 4x4 swap - Page 2 - JeepForum.com
post #16 of 19 Old 02-23-2011, 09:51 AM
crosschecker
1995 XJ Cherokee
Originally Posted by Nickell80 View Post
That's the cool thing about the 42re, it actually has a removable tail which is the OD unit and that is the only difference between 2wd and 4wd for it. I was reading my FSM a little yesterday and that is the first thing it says in the trans removal and install section, that you do not need to remove the complete transmission just to work on the OD unit.
I would still much rather have the Aisin in my Jeep from the factory though.
What you are saying makes no sense. The OD is part of both the 2wd and 4wd tranny, the transfer case is not. You don't add an OD and a transfer case to get 4wd. I could believe that the tail cone is removable and the transfer case might just bolt up, but not that you add and overdrive unit. Adding OD would mean tearing the tranny apart.
Post up your info from the FSM that states the the tail cone is the OD unit, I'd love to see that.
'95 XJ 4.0, 2wd converted to 4wd, manual and stock
'96 XJ 4.0 Country, Auto (The new kid)(now in need of an engine)
'99 WJ 4.0, stock
'96 ZJ 5.2 Limited
crosschecker is offline
post #17 of 19 Old 02-23-2011, 04:10 PM
Nickell80
1997 XJ Cherokee
The OD unit is detachable, for 2wd the unit just has a longer tail and will just connect straight to the drive shaft.
The difference for 4wd is that the OD unit is exactly like it would be on say the AW4, the transfer case just connects directly to it, and you know the rest.
It make sense to me because I've actually seen it, just read some threads about 4wd swaps for the ZJ, it will show you everything.
And here is the best screenshot I could get of it from my FSM, sorry for the size.
White 97 2 Door 4.0 5 Speed XJ
Nickell80 is offline
post #18 of 19 Old 02-23-2011, 05:41 PM
Pugulis
All 4x4's have open dif as standard That's why you'll see everyone talking about installing lockers in the rear. On most every 4x4 your actually geting one drive wheel in the back and one in the front. A limited slip in the rear will help with this a bit. This is why it was standard on the towing package. Hardcore offroaders will instal lockers both front and rear. But this makes driving on the street a little harder on the tires, transfer case, and the dif itself. I'm not saying it can't be or isn't done, but you'll go through tires like crazy. That's also why, in a few years, your going to see more offroad vehicles come with electronic traction control. As it stands now, these systems aren't comparable to a good solid axle.
Pugulis is offline
post #19 of 19 Old 02-25-2011, 09:03 PM
Nickell80
1997 XJ Cherokee
I just found the link to where I first found out about the OD housing stuff for both the OP and Crosschecker to check out.
http://www.mallcrawlin.com/forum/showthread.php?t=8621
2wd , 4x4 , swap
5.9 fan swap jeepguy98 ZJ Grand Cherokee Forum 18 05-13-2010 08:42 AM
doing 247/242 swap....need advice on front output shaft swap.. krazyteggy ZJ Grand Cherokee Forum 5 12-30-2009 06:44 PM
249 to 242 swap on my 94 ZJ j_enniss ZJ Grand Cherokee Forum 3 05-18-2009 06:08 PM
91 -97 Tcase Swap or motor swap ezrider327 ZJ Grand Cherokee Forum 6 05-12-2008 11:47 AM
NP 249 NP 242 Swap 94 ZJ 5.2 Trans Case swap / repair? smkarner ZJ Grand Cherokee Forum 1 09-27-2005 05:28 PM
