2wd, 4wd question. - JeepForum.com
post #1 of 4 Old 08-23-2013, 06:20 AM Thread Starter
RagTagSoldier
2wd, 4wd question.
The jeep I got a couple weeks ago has 2wd 4hi n 4low. Now in 2wd the front drive shaft has some play in it aswell as the frot axles. I can turn them by hand about a tenth of a turn. Is this normal when 4wd is not engaged. The unjoints on the ds look good and there is no play in them. However the from axle ujoints need rebuilt and I cannot see a way to take them apart. Does the entire axle have to be replaced? Also when In park on flat ground you can push the vehicle back and forth about an inch or so. I'm no expert but that doesn't seem right. Help PLz lol
Sent from my iPhone using JeepForum so it probably looks goofy.
RagTagSoldier is offline
post #2 of 4 Old 08-23-2013, 02:58 PM
V65Ozzie
Pretty normal, that's the freeplay in the gears you are feeling.
V65Ozzie is offline
post #3 of 4 Old 08-23-2013, 03:47 PM
zjseeker
Front u-joints probably need replaced. They also make the shaft with u-joints as CV style replacement.
zjseeker is offline
post #4 of 4 Old 08-23-2013, 04:24 PM
tucsonzj
You could budge mine probably an inch or so with no p-brake set. Can with many vehicles.
There is a few ways of splitting a u joint, but youtube some videos, will help ya out. I'm no pro but I know it's out there.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
