2WD to 4WD conversion. Need advice! - Page 2 - JeepForum.com
post #16 of 23 Old 03-21-2012, 10:36 AM
Foundrydude
Doh! I just noticed V6 in the profile.
OP, sell it and buy another. This project is only something you should tackle for the sake of a learning experience, and will probably require you to have alternate transportation for 30 days. Some folks on this forum could do it in a busy weekend, but if you don't know inline versus V engine configuration by sight it's gonna take you a month.
good luck
Foundrydude is offline
post #17 of 23 Old 03-24-2012, 01:08 AM
t_long927
t_long927 is offline
post #18 of 23 Old 07-15-2012, 08:13 PM
cdyt7717
I know this is sorta old, but just wondering cause I considered doing this, has anyone that's done it ever had any problems with the vic or the computer??
cdyt7717 is offline
post #19 of 23 Old 07-16-2012, 06:29 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Yes to both questions.
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #20 of 23 Old 07-18-2012, 12:28 AM
cdyt7717
Did it throw a bunch of cel codes or something? I'm guessing?
cdyt7717 is offline
post #21 of 23 Old 07-20-2012, 03:32 PM
moose27
I just got a 95 limited zj and I'm looking to do the same thing, I actually have a 96 laredo that was totaled out cause of a side swip and was thinking about taking the parts from it and turning my 95 into a 4x4
moose27 is offline
post #22 of 23 Old 07-20-2012, 03:43 PM
JohnnyZJ
whats your time worth?
doing this swap, assuming you have the tools, knowledge, and a full parts jeep in good running order to grab parts off of will run over 1000$. sell current jeep, add 1000$ you were going to spend and get a 4wd.
this is NOT an easy task that you an do on a daily driver type of vehicle. just sourcing parts will be a pain. can some of us do it in a weekend? maybe. will it likely sit in your garage half completed for months at a time? yes.
you will need a 4wd transmission, tcase, front axle and who knows what kind of driveshafts to connect it all up. (lengths could be different) you will also need the computer/TCM stuff as well.
this undertaking is the definition of 'not worth it'
07' JKUR rollin on 35s
JohnnyZJ is offline
post #23 of 23 Old 07-20-2012, 04:23 PM
MrObvious
To your original questions this is what will be needed..
First off will be the computer and the transmission control module. With the pig tails attached. Then you will need a 42RE (assuming your engine) and of course make sure its the 4WD transmission.
Then you will need an complete 4WD front axle (matching gear rations for front and rear)
You will need the transfer case (231/242/249). Also will need the correct input and out put shafts.
Then you will need new/used front and rear drive shafts for the correct lengths
Also you will need the shift linkage for the transfer case (matching one), then cut out the floor of the jeep where that small coin thing is, bolt it into place..
Of course if everything goes as planned its quite an under taking, and it will require quite a bit of knowledge. If you have further questions just ask. But you will need an amazing junkyard with plenty of donor jeeps (of same years/engine) and finding the correct computers/wires/plugs that will all be correctly working.
and an realistic number to be looking at IF EVERYTHING GOES AS PLANNED on the low end will be 800-1000 and the high end 1500-2000
Got it stuck. It's still stuck. It's so stuck I could call insurance and say it was stolen and no one would ever know. It's so stuck I don't know anyone with a capable enough 4x4 to even to to where I got stuck to winch or yank me out.
MrObvious is offline
2wd to 4wd conversion , zj
KOR Trackbar conversion vs. IRO conversion solomon8718 ZJ Grand Cherokee Forum 31 07-04-2012 03:35 PM
Would like advice on U-Joint to CVC conversion craddock01 ZJ Grand Cherokee Forum 9 04-29-2009 07:11 AM
02' HID Conversion mkstarks ZJ Grand Cherokee Forum 7 02-28-2008 11:46 AM
Need Advice on 242 conversion Skyline ZJ Grand Cherokee Forum 3 05-03-2006 10:04 PM
4x2 to 4x4 conversion?? grovesj2 ZJ Grand Cherokee Forum 2 05-04-2005 02:34 PM
