2wd 42re transmission swap - JeepForum.com
post #1 of 7 Old 07-12-2009, 08:34 PM Thread Starter
drespecki
1983 CJ7
Is a 2wd 42re trans (1997 ZJ) the same thing as a 1996 4wd 42re except with a tailpiece? Can that be easily taken off and swapped with a 4wd open ended tailpiece that will bolt up to the transfer case?
It only hurts while you're breathing..
drespecki is offline
post #2 of 7 Old 07-13-2009, 10:35 PM
tazimafied
This can be done. You will have to replace the the tailpiece and the output shaft. Replacing the output shaft on some trannies can be tricky so read up or ask a tech. I would also read up on gearing options for these transmissions as sometimes the gearing will be different between 4WD and 2WD. Hopefully someone else can help shed some light on the subject?
Because I felt like it!
tazimafied is offline
post #3 of 7 Old 07-13-2009, 11:39 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
You need to swap the whole overdrive unit. 4wd and 2wd od housings are different.
ratmonkey is offline
post #4 of 7 Old 07-14-2009, 12:10 AM
iluvtruenos
Just swap trans/transfer case.
Then, when you want to, you can easily convert to 4wd.
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
post #5 of 7 Old 07-14-2009, 11:35 AM Thread Starter
drespecki
1983 CJ7
Is the overdrive unit swapped out easily or do I have to go through the inside to change the output shaft??
post #6 of 7 Old 07-14-2009, 02:32 PM
djjordache
easy straight forward swap.
NO you do not have to swap the main shaft and the gearing is the same.
been there done that:
http://www.mallcrawlin.com/forum/showthread.php?t=8621
djjordache is offline
post #7 of 7 Old 07-20-2009, 09:40 AM Thread Starter
drespecki
1983 CJ7
Sweet..... That helped a lot!
42RE transmission Swap MustangJAB02 ZJ Grand Cherokee Forum 8 05-10-2009 08:38 PM
swap 42re to AW-4 transmission thebgkoolio ZJ Grand Cherokee Forum 2 07-10-2008 04:33 PM
42RE to AW4 swap, transmission discussion UltimatE ZJ Grand Cherokee Forum 3 06-20-2007 08:27 PM
42re Transmission??? 92cherokeesport ZJ Grand Cherokee Forum 9 12-28-2005 12:00 AM
Transmission 42RE DuneCrawler ZJ Grand Cherokee Forum 3 07-02-2004 12:50 PM
