2nd thread - Pulling trans codes (O/D Off light always on) No first or OD? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 2nd thread - Pulling trans codes (O/D Off light always on) No first or OD?
Ruffstuff Axle Simple Swap Kit!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 09-24-2014, 06:33 PM   #1
JaimeZX
Did some research at work, but it hasn't scratched my itch.
'95 ZJ Laredo (if that matters.)
42RE tranny.
Symptoms:
1) Pulling away from a stop it feels like I'm in 2nd gear.
2) Tranny never shifts into overdrive.
3) O/D Off light illuminated at all times.
CEL is not illuminated.
I read to pull the ECM codes, turn the key to the "run" position and then off again four times, then at the fifth, leave it on. The CEL will blink out the codes.
I read to pull the TCM codes, turn the key to the "run" position and then off again two times, then at the third, leave it on. The O/D Off light will blink out the codes.
RESULTS:
* It does not matter whether I turn the key on/off two, three, four, or five times. I get the same result.
* The O/D Off light does not blink, it stays on solid.
* The CEL gives me 12, 55.
NOW
ECM code 12 is "Battery power disconnected in last 50 key cycles." Now why that matters I have no idea, but it's true that the Jeep has a new battery as of about a month ago, which may well be fewer than 50 cycles.
TCM code 12 is "Output shaft sensor input."
Not sure what I'm missing here. If my technique sounds poor I can post a vid.
Thanks in advance!
Edit: SOLUTION ON PAGE 3
JaimeZX is offline   Reply With Quote Quick reply to this message
Unread 09-24-2014, 08:43 PM   #2
herqulees
42RE tranny.
Symptoms:
RESULTS:
NOW
Thanks in advance!
Your transmission lost contact with its output shaft. Code 12 - No Output Shaft Sensor Signal. Doing a quick search I came up with this diagram on Google for where to find the sensor.
Check the wiring for damage and unplug/clean/replug the sensor to see if that helps, if not replace the sensor and it's pretty much guaranteed you're good to go.
herqulees is offline   Reply With Quote Quick reply to this message
Unread 09-24-2014, 09:02 PM   #3
JaimeZX
Okay - that is perfectly logical. I'm still just confused why everywhere I've looked it says the O/D Off light is supposed to blink, but in my case it's the CEL.
I will def. check that wiring this weekend.
Unread 09-25-2014, 01:06 PM   #4
zjosh93
The OD light will blink the trans codes. How long are you waiting for the trans codes. IMS on my 93 it blinks the ECM codes with the check engine light first then the TCM codes on the OD light. Your 95 might be different because your TCM is part of the ECM and on the 93 it's separate. Even with no codes the OD light should still give you a 55. Might check the wiring and plugs on the trans as they can get dirty and loose.
zjosh93 is offline   Reply With Quote Quick reply to this message
Unread 09-25-2014, 01:16 PM   #5
JaimeZX
Interesting; did not know it blinked afterwards. I was just turning the ignition off after the CEL blinked. Thanks!
Set your radio clock!! http://www.jeepforum.com/forum/f13/1993-zj-radio-cassette-clock-623659/
Unread 09-25-2014, 01:24 PM   #6
zjosh93
I think it did on mine but that was a while back. Here's a video of how it's supposed to go:
On that ZJ it seems to blink pretty soon after the key is turned.
Unread 09-25-2014, 02:23 PM   #7
JaimeZX
Welp. I'll try again this evening and we'll see what happens. I may also video.
Unread 09-25-2014, 11:18 PM   #8
PolkaPower
Trans starting in second with o.d. locked out means it's in limp mode.
PolkaPower is offline   Reply With Quote Quick reply to this message
Unread 09-26-2014, 06:24 AM   #9
JaimeZX
Right.
There is always the possibility that I *am* doing this right, and that 5-turns is giving me ECM codes and 3-turns is giving me TCM codes, and I *just happen to have* a 12 on both, so it *appears* it's the same...
I'll look underneath tonight to see if I can figure this out.
Unread 09-26-2014, 06:32 PM   #10
inkedrockstaar
1994 ZJ
i was having about the same problem as yours but mine is a 94. I junk-yarded a few tcm's and one happened to solve my problems but my o/d light didn't work at all, even when cycling the key. and if you put mine in drive it would go into 3rd gear, no 4th or o/d. manually shifting into 1st would put it in 2nd.. but I don't remember what year they stopped with the tcm and ecm being different. Just throwing it out there if you have a tcm. maybe it malfunctioned? and I think the tcm was in zjs 42re i6 until 96?
inkedrockstaar is offline   Reply With Quote Quick reply to this message
Unread 09-26-2014, 06:39 PM   #11
zjosh93
It's three turns for both the engine and trans codes. Just checked mine. The trans codes are at the same time as the engine codes.
Unread 09-26-2014, 08:05 PM   #12
inkedrockstaar
1994 ZJ
12 and 55?
Unread 09-26-2014, 09:20 PM   #13
zjosh93
12, 14, 21, 55 on the check engine.
24, 55 on the OD light.
Unread 09-26-2014, 09:27 PM   #14
herqulees
Only info I can find on code 24 is "24 - Overdrive override (control switch) lamp output", not too sure what to decipher just from that...
Unread 09-26-2014, 09:37 PM   #15
zjosh93
Eh, I was messing around on it a couple weeks ago and had a bunch of stuff unplugged. I was just posting because the OP was having trouble getting the OD light codes. I just need to unplug the battery to erase the codes.
