2nd Gen 4.7 in WJ? - Page 2 - JeepForum.com
post #16 of 26 Old 09-21-2009, 11:37 AM Thread Starter
schmie
alright, thats some useful info. thanks. what would have to be done to the stock pcm to hook in those knock sensors? can i have it reflashed? or look for an ho pcm?
schmie is offline
post #17 of 26 Old 09-21-2009, 12:21 PM
rm2001wj
rm2001wj's Avatar
You can't have you 2000 PCM reflashed because it doesn't even have a place to connect knock sensors. An HO PCM might be possible but then you would need a complete wiring harness from the same HO which would replace your 2000 harness. Finally, there are some subtle differences between a 2002 or later HO PCM/harness and 2000 devices like TCM and BCM.
I personally know of one person, an electrical engineer, who did this, but he never did get things to work in a way that let the CEL turn off.
IMO, trying to get the HO correctly installed would not be worth the time and effort.
rm2001wj is offline
post #18 of 26 Old 09-21-2009, 12:22 PM
xJoshxx
2012 WK
buy a 4.7 and put a 4.7HO internals?
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #19 of 26 Old 09-21-2009, 11:28 PM
ronsaun
2003 WJ
you are buying trouble with this idea! put in a ccompletely compatible motor unless you have weeks to screw around and a bottomless wallet.
ronsaun is offline
post #20 of 26 Old 09-21-2009, 11:41 PM
iluvtruenos
Actually, simply buying the HO camshafts and intake nets a 30hp gain.
The Dakota guys do it all the time.
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
post #21 of 26 Old 09-22-2009, 07:13 AM
CanadianZed-J
The impression I got from rm2001wj is that it's really no problem as long as you forget about the knock sensors and only run premium.
Did I understand correctly? With the high mileage on my 4.7 (195K miles) I'd like to work out my game plan in advance should it eventually go south. An HO would be cool, (even having to run premium all the time), but I sure wouldn't want to run into a mess of electrical crap and a permanent CEL.
I can't get onto WJJeeps.com right now, but there are other enhancements done to beef up the HOs to provide reliability with the added power. And in this case, the OP blew his engine (but I know what you're saying).
CZJ.
So I installed the flux capacitor but the Jeep just won't do 88 mph.
-'99 WJ Limited, 4.7, Patriot Blue, 2" BB, 31" Mall-Terrains, Pavement Princess
-'97 TJ, Stone White, 4" Superlift, 33" SSRs, lunchboxed rear, 12K Titan winch, and 2.5 litres of exhillirating performance.
CanadianZed-J is offline
post #22 of 26 Old 09-22-2009, 07:19 AM
the88thpianoman
2003 WJ
CZJ.
Why not just get an HO upgrade kit? Includes all of the internals to upgrade the standard 4.7 to the HO, and then if yours kicks the bucket, just rebuild it instead of dropping a ton of money on another engine altogether.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #23 of 26 Old 09-22-2009, 07:31 AM
CanadianZed-J
From what I've researched on this site, guys are paying in the neighbourhood of $5000 US to have their 4.7s rebuilt (no, I wouldn't trust myself to rebuild it myself and wouldn't have the time anyway). I'm not sure what a wrecking yard 4.7 costs but I am sure it's far less than that. Also, my uncle owns a body shop/used car dealership so could pick me up a wrecked-in-the-rear WJ at auction for dirt cheap. I swap the engine (I'll do this myself), swap any other things I'd like, then part it out and recoup some of the costs.
This brings me to another point. I'll bet a used car dealership can get you a wrecked WJ with a good motor too. No idea if they'll do this for anyone off the street, but I can't see why not. You can go tell them what kind of car you're looking for and they can buy one at auction for you. It's no different from how they get the rest of their cars on their lots.
CZJ.
post #24 of 26 Old 09-22-2009, 10:51 AM
rm2001wj
rm2001wj's Avatar
CZJ.
About the only thing that might keep this swap from working would be differences between the crankshaft tone ring (for CKP sensor) and camshaft tone ring (for CMP sensor) for the regular 4.7 and the 4.7 HO. I believe that there are differences for some model years, and you would need to confirm that the tones rings are the same for your 4.7 and the proposed 4.7 HO.
If necessarily, the HO camshaft tone ring could probably be changed relatively easily, but I not so sure about the crankshaft tone ring.
rm2001wj is offline
post #25 of 26 Old 09-22-2009, 03:06 PM
dougy147
It will be less, but it might cost all of half of that to get a decent one with 60k miles or so. I thought about getting a JY engine when one of my 4.7 heads cracked. I was looking at almost 2k if I remember correctly for one with 90k miles. I decided to suck it up and spend the 1,000 on heads and misc. parts and a few weekends beating on my jeep.
The Past
95 ZJ Laredo 4.0
00 WJ Laredo 4.0 & 4.7
08 WK Laredo 4.7 (traded for tin can)
The Present
07 JK Unlimited Sahara
dougy147 is offline
post #26 of 26 Old 09-22-2009, 11:26 PM
AgitatedPancake
What about the idea of just dropping the new heads on an old 4.7 block?
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
