2nd Gen 4.7 in WJ? - JeepForum.com
post #1 of 26 Old 09-19-2009, 05:32 PM Thread Starter
schmie
2nd Gen 4.7 in WJ?
Well the 4.7 in my Grand Cherokee grenaded yesterday. The rig is my dd, so I think I'll put in a used motor to get it back on the road quick. My question is this: can I put a second generation 4.7 (2008+) in? I like the sound of an extra 60 horse. Has anyone done this? Would I just be better off with just an HO? Or just stick to the regular one? What kind of electrical issues would I have to address?
schmie is offline
post #2 of 26 Old 09-19-2009, 05:37 PM
duntov
Curious how many miles you had in it?
1998 Jeep Cherokee Classic, Chili Pepper Red, 4.0, 4WD, 3" OME Full Leaf, JKS QD, JL Sub, Sony CD w/Ipod adapter, Polk Audio Speakers, Uniden CB Radio. JCR Front Prerunner bumper, JCR Stage 3 Sliders, Reese hitch, Yakima Rack, Mopar spare tire rack.
2013 Jeep Unlimited, Gecko. Bone Stock.
duntov is offline
post #3 of 26 Old 09-19-2009, 05:39 PM Thread Starter
schmie
130700. Wednesday morning i noticed it was ticking, checked the oil and it was about a quart low, so I changed it in the afternoon. The ticking quit for about 10 miles, then started up again. Then last night it gave. I dunno what exactly is wrong, but the last mile trying to get it into a town i couldnt see out of the rear view because of all the smoke.
schmie is offline
post #4 of 26 Old 09-19-2009, 05:59 PM
xJoshxx
2012 WK
I would love to see a 2nd Gen 4.7
But the 4.7HO will fit no problems.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #5 of 26 Old 09-19-2009, 06:26 PM Thread Starter
schmie
well i mean 2nd gen as in the 2008+ motors, which are rated for 290/330 tq. i understand it would be a long shot finding a wrecked one, but i was entertaining the idea. i may be wrong but i think that they had different heads with 16 spark plugs.
schmie is offline
post #6 of 26 Old 09-19-2009, 10:06 PM
Mikeg175
Would he need to upgrade anything if he went with the H.O. , I know the bolt up would be easy , but what about the electronics ? Ecu and so forth ?
Mikeg175 is offline
post #7 of 26 Old 09-19-2009, 10:14 PM
Texas WJ
Texas WJ's Avatar
2005 WK
...i may be wrong but i think that they had different heads with 16 spark plugs.
Yep, 16.
The engine is rated at 305 hp and 334 lb-ft torque.
Jeep Grand Cherokee WK - Engines
265/70-17 BFGoodrich All-Terrain T/A KO, 2" lift, JK Wrangler Moab wheels, Spidertrax Spacers, Rola Roof Rack.
Texas WJ is offline
post #8 of 26 Old 09-20-2009, 05:48 AM
MuddyLuxury
MuddyLuxury's Avatar
Can the dual spark plugs be wired up to one plug... that just sparks both of them? would need some kind of ignition booster kit.
also, does anybody know if the 3.0 turbo diesel can be put into a WJ??
-Jeb
99 WJ 4.7V8 selc-trac swap
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
in the works... lots deployments are great for jeep budgets
Go Doorless!
Things i need..
good spots in the mid atlantic to camp, hike, fish, kyak and wheel, if you know please share
Originally Posted by 5.9 ANDY
i would do the rear.
MuddyLuxury is offline
post #9 of 26 Old 09-20-2009, 08:44 AM
xJoshxx
2012 WK
anything can be put in it's all the about $$$$
2011 WK2 ORA2 sold
xJoshxx is offline
post #10 of 26 Old 09-20-2009, 11:14 PM
elmer_fud
only one of the plugs would fire if they are in parallel and the spark would be weaker if they were in series. It is not a good idea to wire the plugs together.
Swapping in a diesel engine requires a lot of custom fabrication and electronics
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #11 of 26 Old 09-21-2009, 08:57 AM
Mikeg175
Semi-hijacking here , but I have a lot of miles on my standard 4.7 and was wondering other then motor , what else would have to be installed/removed to make a H.O. work . I'd like the extra hp , if there is a ton of work , probably not worth it to me . Thanks
Mikeg175 is offline
post #12 of 26 Old 09-21-2009, 09:58 AM Thread Starter
schmie
Mikeg175:
thats not a hijack. im thinking the same. i was doing a little more looking around and it looks like the 2008+ motor isnt really gonna work. but how about that HO? has anybody done this? could i get by with putting the motor in and getting a reflash?
schmie is offline
post #13 of 26 Old 09-21-2009, 10:11 AM
rm2001wj
rm2001wj's Avatar
First of probably several electrical problems would be that the HO has two knock sensors which allows its PCM to adjust timing when regular gas is used instead premium. As you might expect, your regular 4.7 PCM can't use knock sensor signals. With a 9.7:1 compression ratio, you would be stuck with using premium in the HO.
rm2001wj is offline
post #14 of 26 Old 09-21-2009, 10:22 AM
CanadianZed-J
So the HO PCM defaults on the super-timing?
CZJ.
So I installed the flux capacitor but the Jeep just won't do 88 mph.
-'99 WJ Limited, 4.7, Patriot Blue, 2" BB, 31" Mall-Terrains, Pavement Princess
-'97 TJ, Stone White, 4" Superlift, 33" SSRs, lunchboxed rear, 12K Titan winch, and 2.5 litres of exhillirating performance.
CanadianZed-J is offline
post #15 of 26 Old 09-21-2009, 10:56 AM
rm2001wj
rm2001wj's Avatar
CZJ.
Yes, that's the only way it can tell if regular (knock sensors detect knocking) or premium (knock sensors don't detect knocking) is being used. However, if regular has been burned for a while (timing pulled), and then there is a fill up of premium, the timing does not immediately advance. The PCM waits for several gallons to be burned before going up on the timing. That's why some people say that there is no performance difference between the two grades, because there isn't initially.
rm2001wj is offline
