2inch poly spacers ontop of 4inch lift? - JeepForum.com
post #1 of 7 Old 07-19-2009, 09:23 PM Thread Starter
JkTheItalianoWJ
Is it possible to put the 2 inch poly spacers on top of a 4 inch lift by placing them ontop of the coils to get a cheap and easy 6inches of lift? or is that just a really bad idea?
JkTheItalianoWJ is offline
post #2 of 7 Old 07-19-2009, 09:37 PM
the88thpianoman
2003 WJ
It's a great idea... if you get longer shocks, all new control arms, change the A arm setup in the back, replace your front and rear sway bar links, change your front driveshaft to double cardon u joints, look into modding the rear shaft as well, and basically get rid of every single part for your 4 inch lift and buy a 6 inch lift. But if you're not going to do all that, then no.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #3 of 7 Old 07-19-2009, 10:08 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Brian
WJ, WK, CJ5
GraKee99 is offline
post #4 of 7 Old 07-19-2009, 10:27 PM
Virmagicus
Virmagicus's Avatar
Buy a ZJ.... it will be alot easier.
Jeff
Virmagicus is offline
post #5 of 7 Old 08-05-2009, 04:56 PM
blackwhiteriot
lol so if i buy a 3.5 can i put my bb on top of it. and not have to replace everything that he named? for my zj of course.
blackwhiteriot is offline
post #6 of 7 Old 08-05-2009, 05:08 PM
sandman
^^^^^^ no ^^^^^^^
1993 Jeep ZJ. 4.0
sandman is offline
post #7 of 7 Old 08-07-2009, 10:49 AM
ZJTechie
If you look at the ZJ/WJ forum stickies there are MANY links to lifts, theory and approaches. The general idea I have gleaned from reading all that was that lifting over 4.5 inches WILL require much more money and parts. Geometry for these vehicles seems to choose the 4.5" as a "magic number", though I am unsure as to whether that applies to the WJ exactly. In short, if you wish to look at lifts over four inches, you will NEED to spend a huge amount to make everything work correctly and SAFELY on and off the trail. There is NO other way around it. Keep your lift shorter and you will avoid lots of headaches and wallet burning.
ZJTechie,
My current JEEP score: 205 (see site below)
ZJTechie is offline
already have 4inch lift...want to add BB Travis873o ZJ Grand Cherokee Forum 2 10-23-2009 10:58 PM
2inch spacers? 2004freedom ZJ Grand Cherokee Forum 13 03-04-2009 06:08 PM
Is it possible to stack 2 inch poly spacers? steelmill88 ZJ Grand Cherokee Forum 15 10-26-2008 07:04 PM
1 inch poly spacers Death-Mobile ZJ Grand Cherokee Forum 4 12-20-2005 10:36 PM
shocks for 2inch BB Lift onlyone ZJ Grand Cherokee Forum 4 03-06-2004 02:35 PM
