249, VC and bunny hop. Why? - JeepForum.com
post #1 of 6 Old 04-30-2013, 05:17 AM Thread Starter
Adam86
Why does the transfer case cause this?
If the t/c is just sending power to the axle and its the axles job to allow the wheels to rotate at different speeds why is it the t/c that causes the wheels to skip whilst turning?
Adam86 is offline
post #2 of 6 Old 04-30-2013, 06:14 AM
Timo_90xj
Timo_90xj's Avatar
Axles only split power between each side. Transfer case splits the power between front and rear. If the wheelhop happens in AWD mode, it means your viscous coupling is shot and needs to be replaced.
If the wheelhop happens in 4lo, it is normal behavior because in 4lo front and rear axles are locked together providing you with maximum traction.
***Under construction***
Timo_90xj is offline
post #3 of 6 Old 04-30-2013, 07:07 AM Thread Starter
Adam86
Ok so im getting wheel hop whilst turning is that down to the axle because they split power from side to side?
If you get wheel hop in a strait line its the transfer case?
Adam86 is offline
post #4 of 6 Old 04-30-2013, 07:12 AM
Snowfan2
If you get wheel hop in a straight line something is seriously wrong. When turning, the front tires follow a longer path than the rears, that is what causes the binding when they are locked together as with a blown VC.
Snowfan2 is offline
post #5 of 6 Old 04-30-2013, 07:43 AM Thread Starter
Adam86
Perfect, that's the reasoning answer I was looking for!
Didn't know the vc locked when in low on the 4.0. Nice info cheers.
I just get a bit of hop whilest turning was just using strait line as an example lol.
Cheers all!
Adam86 is offline
post #6 of 6 Old 04-30-2013, 08:01 AM
Timo_90xj
Timo_90xj's Avatar
No, like I just wrote you get wheelhop because of a failed VC.
You would only get wheelhop or binding driving in a staright line if you had different gear ratios in front & rear axles. There is no wheelspeed differences to account for when driving straight.
