249 Transfer case rebuild - JeepForum.com
 1Likes
post #1 of 35 Old 12-03-2009, 08:35 AM Thread Starter
Skates
1994 ZJ
Any ideas where I can find parts to rebuild my 249 tc?
Skates is offline
post #2 of 35 Old 12-03-2009, 08:46 AM
rugermack
Don't rebuild it, bearing kit around $100-125 chain $150 viscous coulper $400, swap in a np242 or np231.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
post #3 of 35 Old 12-03-2009, 09:42 AM
CrazyIvan888
^What he said. The VC will cost you more than a used 242 transfer case. I swapped in a 242 on mine, best thing I ever did for it.
CrazyIvan888 is offline
post #4 of 35 Old 12-03-2009, 02:54 PM Thread Starter
Skates
1994 ZJ
How will that effect the all time four wheel drive?
Skates is offline
post #5 of 35 Old 12-03-2009, 02:56 PM
ZeJokee
You will still have all wheel drive but with the added option of 2wd
99 WJ Ltd, Blacked out, 4.7L, 242j Swap, 2'' BB, 245/75/16 Kuhmo Venture AT KL78, Flow Master Super 40, MagnaFlow high flow Cat, Akebono caliper upgrade, Addco rear swaybar, Westin brush guard, Moog Super Trail Boss, Rancho RS5000, Rola roof rack with dual kayak J hooks, PAC-AOEM-CHR, Sony Xplod 1200w amp, 2 Sony Xplod 12'' subs, 118,XXX miles (SOLD)
93 ZJ Ltd, Blacked out, 5.2L, Reman 46RH, Reman 242 Swap, 3.5'' IRO + 2" BB, 33x12.50r15 Mud Claw MTX radials, Bushwacker Flares, 216,XXX miles (Still parked in NC)
04 F-350 SD Crew Cab FX4 Lariat, 6.0 PSD SRW, Head studs, AFE Stage 2 SI Pro Guard 7 intake, Blue Spring mod, 150,XXX Miles
ZeJokee is offline
post #6 of 35 Old 12-03-2009, 02:56 PM Thread Starter
Skates
1994 ZJ
Originally Posted by rugermack View Post
Don't rebuild it, bearing kit around $100-125 chain $150 viscous coupler $400, swap in a np242 or np231.
how would that effect my all time four wheel drive?
Skates is offline
post #7 of 35 Old 12-03-2009, 03:00 PM Thread Starter
Skates
1994 ZJ
Ok that would be better then due to the fact we mainly use as a daily driver. When you buy the 231 or 242 does a new shifter come with it to tell if you are in 4 hi or lo and what about locking the hubs?
Skates is offline
post #8 of 35 Old 12-03-2009, 04:39 PM
cmonson
search the board for a 249 to 242 swap. Most people won't even comment on this thread b/c it comes up every 3 days and get tired of writting the same thing over and over...
cmonson is offline
post #9 of 35 Old 12-03-2009, 06:21 PM
JesseOR
I found many sites with parts for the rebuild, just google it and you will see the high cost.
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline
post #10 of 35 Old 12-03-2009, 07:13 PM Thread Starter
Skates
1994 ZJ
I believe I'm going to just do a swap. I found a write up on it and i like the option of 2wd instead of all time 4wd. I will post pics when I get it completed.
Skates is offline
post #11 of 35 Old 12-03-2009, 08:56 PM
CrazyIvan888
Note that the 231 will not give you the AWD option. You will only have part-time 4WD and 2WD. Get a 242 if you can.
post #12 of 35 Old 12-03-2009, 09:27 PM
ZJPunk98
I didn't read the whole thread yet, but most people will tell you not to rebuild the 249 because of the cost. Yes it is true, the 249 VC is expensive to replace. I was in the same situation your are in now. I couldn't decide between cashing out and buying the 249 rebuild kit or doing a swap to the 242 as most people will do.
I like my 249 and the way it works so i decided finally to rebuild, i purchased everything from Nick Kolak, he is on here quite frequently. I paid $500 for my overhaul kit, that is the VC, chain, and seals and all.
The kit just arrived this afternoon. I'm hoping to rebuild it this weekend. I know its a lot of money, but i like the way the 249 works and its never failed me in the snowy/icy winters.
note: the 4wd function in the 249 and 242 are NOT the same. the 242 is not a "locked" tc like the 249 in 4wd. in the 242 your will have to use parttime 4wd to have the locking action, which in this model is not good on the pavement.
dotahoe likes this.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
post #13 of 35 Old 12-03-2009, 11:30 PM
CrazyIvan888
Originally Posted by ZJPunk98 View Post
I didn't read the whole thread yet...
It's only a dozen posts!
And the 242 does have a full-time 4WD mode which will get you through just about any on-road conditions you may encounter, if it gets really rough or if you're going off-road, you can just pop it in to part-time mode.
I agree that the 242 does lack the "handsfree" convenience of the 249 though.
post #14 of 35 Old 12-04-2009, 02:22 PM
ZJPunk98
yeah i know, but i was in a rush to get out the door.
Erik
ZJPunk98 is offline
post #15 of 35 Old 12-06-2009, 02:45 PM Thread Starter
Skates
1994 ZJ
Thanks everyone
Skates is offline
**242 Transfer Case Rebuild Help!** 1998JGC ZJ Grand Cherokee Forum 5 12-14-2009 09:23 PM
Transfer Case rebuild kit? kruzy13 WK Grand Cherokee & XK Commander Forum 2 11-16-2009 10:14 AM
Anyone rebuild a transfer case? Reswob ZJ Grand Cherokee Forum 1 03-25-2009 01:51 PM
Transfer case Upgrade or Rebuild? UUJ1 ZJ Grand Cherokee Forum 4 03-20-2007 09:42 AM
Transfer case rebuild micifus ZJ Grand Cherokee Forum 10 09-04-2006 08:01 PM
