249 TC damaged w/o front DS - JeepForum.com
post #1 of 6 Old 04-27-2005, 11:50 AM Thread Starter
chapin14
Does anyone know if it damages the VC in a 249 TC if the truck is driven without a front drive shaft. A friend removed the front DS because he thought a u joint was bad and now his VC is bad. Did it go bad because of the DS being out, or was the VC the original problem? Thanks.
chapin14 is offline
post #2 of 6 Old 04-27-2005, 02:41 PM
Mustang
Check Out this thread it may have some good info
http://www.jeepforum.com/forum/f13/drive-shaft-153989/
Mustang is offline
post #3 of 6 Old 04-27-2005, 02:52 PM
5point9Limited
5point9Limited's Avatar
I removed mine yesterday to do smokey burn outs!! I will be putting it back in asap because iits not good to drive with out it.
1997 TJ 4.0, 5 Speed, Stock
Sold: 1998 Grand Cherokee 5.9 Limited
5point9Limited is offline
post #4 of 6 Old 04-28-2005, 06:33 AM
greasefingers
greasefingers's Avatar
1994 ZJ
I was told by a Ford mechanic that the TC needs to be loaded as it was designed to. Otherwise the chain will have slack in it, without the front driveshft and it will go bad.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #5 of 6 Old 05-01-2005, 08:06 PM
savage3c
Bad U Joint idea was the clue. The VC is /was bad. Went through a whole lot of replacement parts till I replaced the VC.
For those of you that want to run w/o the front drive shaft. Beware, in park, without the front DS, it will creep and you may not find the jeep where you left it.
Cheers
savage3c is offline
post #6 of 6 Old 05-02-2005, 12:00 AM
robosterman59
Cheers
It'll only roll in earlier 249 T-cases.
robosterman59 is offline
Damaged 4x4 in a WJ!?! 01TJfuntime WJ Grand Cherokee Forum 6 07-21-2010 08:49 PM
Front axle shaft damaged. Acidcold WK Grand Cherokee & XK Commander Forum 12 03-23-2009 03:42 PM
Damaged Subwoofer Fix? greasefingers ZJ Grand Cherokee Forum 19 01-06-2008 05:16 AM
Damaged 02 Sensors? adgjqetuo ZJ Grand Cherokee Forum 6 06-06-2007 12:43 PM
Damaged bumpers graham_1964 ZJ Grand Cherokee Forum 1 11-29-2005 06:48 PM
