249 replacement. Been searching i just a have one question. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 249 replacement. Been searching i just a have one question.
New! JK/U skid plate system.We now have Uniballs!The Original 3/8" Ruffstuff Diff Cover!
Unread 03-08-2015, 04:04 PM   #1
AlpineStar94
So my transfer case self destructed. (95 ZJ limited 5.2) instead of going through all the trouble to swap in a 231/242, would it be possible to just buy a 96+ 249 with lo-lock and bolt it in? I don't have funds to be buying different parts And cases from different year jeeps. Would I only have to replace my input shaft if it's a different length? I understand there's over a million threads on this already so instead of telling me to search and hammering me on it is prefer you not comment. I'm just looking for the absolute cheapest and fastest way to get this thing rolling WITHOUT putting in a 93-95 249. I'm not so mechanically inclined and I'm currently catching rides to work that's killing me on gas money. So any help would be appreciated
AlpineStar94 is offline   Reply With Quote Quick reply to this message
Unread 03-08-2015, 10:38 PM   #2
fishermandave95
sorry dude but CHEEPEST AND FASTEST is a 95 249 , , how much of the swap sticky have ya read ? it has what yrs are compatible with what in it , 93-95 V8 ZJ's: 46RH transmission, 1.55" 23 spline input shaft
93-95 I6 ZJ's with the 42RE: .840" 23 spline input (with collar)
93 I6 ZJ's with the AW4 or AX15: .750" 23 spline input
All 96-98 ZJ's: .840" 23 spline input
All 96-01 XJ's: .840" 23 spline input
92-95 XJ's: .750" 23 spline input
91 and older XJ's: .750" 21 spline input
JEEP WAVE Y'ALL
I FISH THEREFORE I AM !!
fishermandave95 is offline   Reply With Quote Quick reply to this message
Unread 03-09-2015, 12:29 AM   #3
MurdaJs
If he has the late gear cut why can't he swap his 1.55 input into a 96+ 249? The drive shafts should be fine
Edit: my bad I missed the "not mechanically inclined" part.
96 SCT tuned 5.2, NV3500, 231, Hp30 TrueTrac 3-link, 8.8 Lokka Double Tri 4-link, Coilovers
98 5.9
MurdaJs is offline   Reply With Quote Quick reply to this message
Unread 03-09-2015, 12:33 AM   #4
PolkaPower
There is no way to tell what the condition of a used viscous coupler is, so it's not a good idea to swap in used 249's.
Best bet is to replace the viscous coupler in the case you have.
PolkaPower is offline   Reply With Quote Quick reply to this message
Unread 03-09-2015, 12:34 AM   #5
fishermandave95
Probly best to let a shop swap in a reman and call it a day and have a Pepsi
JEEP WAVE Y'ALL
Unread 03-09-2015, 12:38 AM   #6
fishermandave95
The VC and other parts are someplace on the hwy
JEEP WAVE Y'ALL
Unread 03-09-2015, 01:13 AM   #7
PolkaPower
Swapping a used 249 is gambling. There is no way to tell.
Unread 03-09-2015, 01:19 AM   #8
fishermandave95
I agree . Just like used any thing . He wants cheep and now . IF he can find one and swap it his self save a little and hope for best . Cheep fix is cheep fix . Why I will never buy used motor or 700 cash trany fix ever again
JEEP WAVE Y'ALL
Unread 03-09-2015, 02:43 AM   #9
kg6mov
Hears the voices
kg6mov's Avatar
Easiest OR cheapest, pick one.
Easiest would be buying a prebuilt case, many places will sell you a 231 with whatever input shaft you want. You could also go for a reman 249 or a hybrid 247.
Cheapest would be biting the bullet and building your own case from JY parts, you can take a 96+ case and swap your input shaft in, replace the vc and call it a day. That would be a very good case. You could also run a second gen 249 WITHOUT the VC which would give you 2wd and 4lo.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, Backyard parts fodder
kg6mov is offline   Reply With Quote Quick reply to this message
Unread 03-09-2015, 08:37 AM   #10
AlpineStar94
Thanks. This is the route I'm leaning hard at. So to clarify, I need to find 96-98 grand Cherokee v8 at a jy, pull the 2G 249, swap in my 1.55" input shaft with the .840 that *should* be in there stock and it's good to go? Another thing. Is the length say .840, how much it sticks out past the complete tc, or is it the overall length of the whole input shaft. do you have to split the case open just to find out if it's the correct length? Hate to buy one and it be the wrong size lol. Other than that I appreciate the clarifications.
Unread 03-09-2015, 08:50 AM   #11
AlpineStar94
Just called a local jy he said he has a 242 in a 96-98 gc. This is not stock is it? He quoted $350 and it's almost walking distance to my house. If this will be compatible I'll slap that baby in. What do you guys think?
Unread 03-09-2015, 09:01 AM   #12
PolkaPower
Its' stock. It's probably out of a 4.0 unless someone swapped in a V8. Price is a bit high I hope it comes with a good warranty. It should be closer to 150.
Unread 03-09-2015, 09:09 AM   #13
AlpineStar94
That's good to know. He'll be pulling it for me. I'm gonna shop around cause it's gonna be a week before I can get one so that should be time to find a good price. I couldn't find one for less than $200 online.
Unread 03-09-2015, 09:11 AM   #14
AlpineStar94
2wd? Didnt know that came in any 249
Unread 03-09-2015, 09:13 AM   #15
PolkaPower
When you remove the front shaft it's rear wheel drive. Taking out the VC takes the front shaft out of play making it RWD but when you put it in 4lo it locks the front and rear drive shafts together.
