249 to 242 swap done - JeepForum.com
post #1 of 5 Old 07-11-2009, 01:11 PM Thread Starter
indianajeep
indianajeep's Avatar
2005 WK
96 zj, 5.2l - had 249. I swapped in a 242 from a 98 ZJ. The input shaft was a match. Front driveshaft fit perfectly. I had to shorten the rear driveshaft. The ZJ is stock in every other way - no lifts, etc. The 242 case was 1 inch longer overall, so I had the driveshaft shop cut off 1 inch. It seemed liked it still needed more room when I installed it. Has anyone else without a lift had to shorten their driveshaft, and if so, how much was it shortened?
indianajeep is offline
post #2 of 5 Old 07-11-2009, 06:27 PM Thread Starter
indianajeep
2005 WK
bump? anyone?
post #3 of 5 Old 07-12-2009, 09:26 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
you should have just driven to the shop in front wheel drive and let them measure what's needed.
with no lift you probably should have lopped about 2" off of the shaft.
i'd need more than an inch at 4.5" of lift if i weren't going to a shorter transmission soon.
ratmonkey is offline
post #4 of 5 Old 07-12-2009, 09:27 PM Thread Starter
indianajeep
2005 WK
I removed the driveshaft and measured from the end of the output shaft to the middle of the rear yoke. The driveshaft now has just under 1/2 inch of travel before it bottoms out. I am going to have the shop shorten by another 3/4 of an inch. That should put it at just over 1 inch of travel before bottoming out as measured with all four on the ground.
post #5 of 5 Old 07-12-2009, 10:04 PM
nashmd454
nashmd454's Avatar
when I did my swap...the shop didn't sawp out the input output shafts and therefore had to lop off 1" on the ds as well.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
doing 247/242 swap....need advice on front output shaft swap.. krazyteggy ZJ Grand Cherokee Forum 5 12-30-2009 06:44 PM
V8 to I6 swap snakeeyes237 ZJ Grand Cherokee Forum 3 11-04-2009 05:24 AM
8.8 swap? dank10 ZJ Grand Cherokee Forum 6 03-16-2009 02:25 PM
91 -97 Tcase Swap or motor swap ezrider327 ZJ Grand Cherokee Forum 6 05-12-2008 11:47 AM
NP 249 NP 242 Swap 94 ZJ 5.2 Trans Case swap / repair? smkarner ZJ Grand Cherokee Forum 1 09-27-2005 05:28 PM
