Quantcast 249 -> 242 swap completed *pics* - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 249 -> 242 swap completed *pics*
Truck-Lite's New LED Headlamp SeriesRuffstuff Axle Simple Swap Kit!Spartan Lockers FREE SHIPPING Excellent Prices
Old 04-01-2008, 10:31 PM   #91
drespecki
Kruzin, what year/model did you get the donor 231 for your 1997? Thanks..
It only hurts while you're breathing..
drespecki is offline   Reply With Quote
Old 04-01-2008, 10:58 PM   #92
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
WOW back from the dead.
most 231s are the same, not much difference between them, just get one that is the closested year as yours. i got mine out of a 1992 dodge dakota.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:http://www.jeepforum.com/forum/f197/5-9-andys-1-ton-zj-build-american-standard-1056365/
5.9 ANDY is offline   Reply With Quote
Old 04-01-2008, 11:16 PM   #93
Virmagicus
Headed Out West
Virmagicus's Avatar
Originally Posted by blovingier View Post
EMTimZJ, how much fluid came out when you pulled that seal off the back of the tranny and how fast did it flow out? I know it's been awhile since you did all that, but was just curious if you remembered or not. I need to replace mine, but didn't have the right seal when I changed out the bearing seal on the TCase today. Thanks.
Good question.
Virmagicus is offline   Reply With Quote
Old 04-01-2008, 11:22 PM   #94
Kruzin
Mine's a '93, and AFAIK, the donor came from a '93 ZJ. I bought it off an e-bay Jeep junk yard (which is no longer selling on e-bay). The yellow paint pen marking said "93 zj".
DD: 98 ZJ Laredo 5.2, all stock
Wheeler/Beater: 93 ZJ Laredo
4.0, AW4, 231 conversion from 249
3" coil lift, JKS Adjustable Track Bar, JKS Quicker Discos, KOR lwr rad supt, Brush guard
Colorado Jeep Club Member 242 (4.0L)
Kruzin is offline   Reply With Quote
Old 04-01-2008, 11:49 PM   #95
drespecki
I have the 1996 5.2 with a 44re trans and 249 transfer case.. I am looking for 231 donor that will work for that year..
Old 04-01-2008, 11:56 PM   #96
drespecki
I have a line on this 1997 XJ 231 but I do not recognize the output shaft with the condom looking thing on it... My 249 is a cone with a hole in it I believe..
Old 04-02-2008, 02:09 AM   #97
Swamp Boy
That tail shaft is same as yours just exposed shaft instead of covered shaft.. (At least thats what I think.. )
I had a simular issue when I did the swap for someone else but I think it worked out.. ( I honestly dont remember cause it was years ago..) But I think I would remember it better if it had been a problem...
Measure total length of both cases thats you determining factor.. If they are both the same length you are golden...
Just another soccer moms Grocery getter....
[Url]http://www.jeepforum.com/gallery/files//8/5/6/5/hatt034.jpg[/url]
Swamp Boy is offline   Reply With Quote
Old 04-02-2008, 09:39 AM   #98
drespecki
It seems like my old 249 does not have the long exposed shaft, it is inside the tailpiece housing and the drive shaft goes into the housing. I think that this long output shaft would have to come off. Do I have to swap over the 249 input shaft then? Maybe it would be easier to find one with a shorter ouput shaft that does not have to be swapped out? Some pics of the 249 and some of the 231 with the long output shaft..
Old 04-02-2008, 09:45 AM   #99
drespecki
Ooops, here are the pics.
Old 04-04-2008, 03:44 PM   #100
drespecki
No one?? I am stumped as to what direction I should take...
Old 04-04-2008, 03:49 PM   #101
drespecki
Here is the exact beast still in my 1996 5.2..... It has the tailpiece whereas the the 242 that I purchased has a shorter taipiece with the output shaft sticking out... What should I do?
Old 04-05-2008, 09:03 AM   #102
drespecki
Anyone able to help on this one?? I need to figure out which way to approach these two different output shafts...
Old 04-11-2008, 04:25 PM   #103
SpeedyCat3
Survivor
SpeedyCat3's Avatar
Is your driveshaft spline count the same as the new 242j?
From the looks of it the DS should dlide right in.
From what I understand normally the problem is in the input shaft,
between the tranny and the TC.
I am doing the same swap but with a newer (2004) 242J, and it does
not have the speedo hole, so I am waiting to resolve that part...
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
My 97 ZJ Build
SpeedyCat3 is offline   Reply With Quote
Old 05-17-2008, 10:33 PM   #104
Virmagicus
Headed Out West
Virmagicus's Avatar
I just swapped a 242 in my ZJ today out of a 94 XJ . I had to swap out the input shaft because my old 249 had the 1.750" exposed shaft. The 242 had the .850" exposed shaft. This way you are guaranteed a good seal at rear of the tranny if you have the longer input shaft. I also picked up the shift bezel from a ZJ that had a 242. What I did with great success was use all of the stock ZJ shift linkages. The 242 must have a short shift lever in order to function properly. The 249 shift lever will not work as it is to long. Surprisingly, it now shifts effortlessly and is very easy to distinguish between proper modes after a little adjusting.
Old 08-06-2008, 09:40 PM   #105
hydra
man, it would be really great if there were a table somewhere of which years/models have 242's that are:
- directly compatible, bolt-in
- bolt-in, but missing VSS-port
- same rear-output; but wrong input-length
- correct input spline/length, but wrong R-output
etc...etc...
It sounds like, as usual ....jeep used different parts even within the same year....but man, there's gotta be -some- kind of guide to which years/models.
I'll be buying a rollover or blown-engine donor XJ to get my case (and an AX15 for future conversion to 5-speed and turbodiesel).....so I REALLY want to be sure of getting the right case.....can't afford to buy the wrong XJ three times in a row...
ps; good thread! I've been copy/pasting the useful bits to a notes-file....good stuff!
hydra is offline   Reply With Quote
Glock Forum
