#61 | ||
David. 94 ZJ laredo 5.2 V8 soon to be 5.9!! In Delaware, the largest growth of population is Indian Americans, moving from India. You cannot go to a 7/11 or a Dunkin’ Donuts unless you have a slight Indian accent. I’m not joking. Joe Biden |
#62 |
Always a Pirate
okay so here's what i've taken everyone's answers on three different forums to. the case will bolt up, but i will need to have the rear shaft shortened, can that be done. supposedly i can take it to a driveshaft guy, but i never knew that. anyone know if i can buy a different shaft?
#63 |
GSMW!
Sure you can buy whatever length shaft you want. However getting you old one shortened is really not expensive at all. $50 is more than fair for something like that. (shortening)
-Tim GS-MW 2009 INFO KD8EBC '94 ZJ 5.2 LTD Project TORTOISE Build-up thread JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick |
#64 |
Always a Pirate
well where would i buy one, out of curiosity?
#65 | |
#66 |
Always a Pirate
okay i feel kinda dumb. the whole time I thought everyone was talking about the actual T/C output shaft
. sorry all, so the actual driveshaft has to be shortened huh? i guess just measure it and send it to the shop? |
#67 | |
GSMW!
#68 | |
#69 |
Always a Pirate
well i was talking to Tom Woods and he was saying that on the late style 242 i would have to lengthen it. so i am assuming i'll either have to keep it the same or shorten the later 242.
just so i know, where should i measure from? and wouldn't it be a bad thing to drive around in "4wd" (really Front WD) without the rear shaft? won't it throw a check light or code or something? |
#70 |
The DS shop will probably want to know the length from u-joint to u-joint.
It would be bad to drive without your rear shaft. Not because of a check light, but because it's a slip in yoke at the tcase. You would loose some fluid without the shaft sealing against the rear output seal.
DD: 98 ZJ Laredo 5.2, all stock Wheeler/Beater: 93 ZJ Laredo 4.0, AW4, 231 conversion from 249 3" coil lift, JKS Adjustable Track Bar, JKS Quicker Discos, KOR lwr rad supt, Brush guard Colorado Jeep Club Member 242 (4.0L) |
#71 |
Always a Pirate
thats what i thought, about driving it like that...
but with the drive shaft measurement. would it be like from midlin of u-join to midline ot like where tailshaft ends to the u-joint or some cariation thereof? |
#72 | |
http://www.4xshaft.com/index.html scroll down to step #3
#73 | |
Russ 02 Dakota Quad Cab 4.7 5 spd 93 ZJ Stolen and wrecked Mar29/08 |
#74 |
FYI if there is any doubt as to the input shaft, planetary gear cut etc. this swap can also be accomplished using the front half of your existing 249 and planetary mated with the back half and the internals of the donor 242. the only "mod" is to drill a 5/16 hole in the 249 front half for the rubber plug used to access the 242 low range fork lock pin. My "249/242" case has been in my ZJ for a year and a half and over 20K miles with zero problems.
#75 |
Always a Pirate
hmm, thats an interesting option. do you have any pics? is it easy to change over the internals?
as far as the leaking question, my new t/c will prolly have an external slipyoke. no leakage, but no pressure from the rear drive shaft is there a chance of it slipping out? wow bad thought in my head on that, o boy that'd suck. then i'll have a leak!! ![]() |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
