249 -> 242 swap completed *pics*
#46 | |
well it all done finished the 249 to 242 swap
![]() thanks for all the help!!!!!
Tater BLACK 97 ZJ 4.0L-42re-242-DANA 30/35 (3.73)
MODS) 2in lift-30x9.5x15 BFG A/T-15x8 Pacer Wheels-K&N Intake-1in TB Spacer-40Series Flowmaster-Hi-Flow Cat-JKS Trackbar-Sliderz-BDS adj CA-BDS SS-Cobra19 ULTRA III-FireStick4FT-PA Horn-Hella500 DL-Roof Rack-TC Skid-Gastank Skid |
#47 | |
on a scale on 1 to 10 how hard do is this? for an average person?
2002 WJ Laredo 4.7 97 XJ 4.0 AW4 150k Harness Upgrade, PIAA intense white bulbs. Soon to have 6.5LA and 33x12.50 97 ZJ 5.2 Limited 144k 31x10.50 MT's Flowmaster Super 44 (http://www.youtube.com/watch?v=pzi9wYMGpVU) Quote:
#48 |
With changing a spare tire being a 1 and say swapping out an engine being around an 8 id give it around a 4 or 5 maybe.
If your not rebuilding it its even easier. Its really just a matter of unbolting the old one and botling the new one back up. |
#49 |
Mr. Hyde!
Like 99% of Jeep things, there is a step learning curve of tricks of the trade the first time. First time may take you 8 hours, second time may take you 30 minutes...
'04 WJ, 6" Clayton LA's, 242 SYE, 35" BFG MT KM2's, 4.56 gears, & D44a locked |
#50 |
#51 |
Quick Question What are the Shaft lengths? I am looking into this swap, and I own a 93' ZJ so which TC should I be looking for? and out of what vehicle?
Western Oregon University 93' Grand Cherokee ZJ 5.2L(Dead) |
#52 |
I have a 94 zj with a v8. Was looking to swap a 96 242 from a I6 zj. The 96 does not have a trail shaft housing like the 94, just splines with a boot. Was wondering it the shaft is the same length or am I going to have drive shaft issues. I can probably get the drive shaft from the 96 if it will work being behind a I6. I would'nt think they would relocate the transfercase from a v8 to I6 but thought I would ask first. Thanks George.
George. 1994 ZJ, 318 (5.2), (Was NP249) Now NP 242 external slip, 2" BB lift, 235/75/15 Bridgestone TA ko's. |
#53 |
I haven't done this swap yet but I think we are in the same boat. The 93-95 ZJs have a different gear cut and spline count for the input shaft than the newer Jeeps. You can swap the shafts but the gear cut will make for a very noisy transfer case.
Transfer cases from Jeeps earlier than 1995 should work but you may have to swap the input shafts to get the correct spline count. Apparently there are different rear driveshaft lengths as well depending on what you got the case from. Hopefully the experts can correct any incorrect information. |
#54 |
im confused isnt the 242 the stock tc for the 96 laredo?? from what ive read here it has the 2wd option. if this is correct why do i not have the 2wd option? i have the buildsheet but it doesnt say what tc i have. im just assuming its the 242
#55 |
4.0 Piston Skirt Victim
As usual a very professional write up.
WALTER |
#56 | |
There were two cases available. The 242, and the 249. 242 is 2wd/4wd/n/4lo where as the 249 is all wheel drive/n/4lo. The spline count is only different if you take out of a jeep from before 89 I believe. It was 21 splines for the Tcase input, but they changed it to a 23 spline input. |
#57 |
so which one is the better case?
#58 |
Always a Pirate
reviving the thread here...i plan on doing the 249 to 242 swap. i am going to be getting a T/C that was from a 96-98 grand (most likely a 97) and will hopefully get full linkage for it (or buy new linkages). i was wondering about the output shafts. i've heard 8 million different things about them: change the planetary, cut the shaft, it'll bolt right in, etc, etc
. its starting to get on my nerves...hahai would like to know once and for all, with using a 242 from the same model year as my truck (97 ZJ with a 5.2) what exactly will i have to do??? |
#59 | |
'98 ZJ Laredo 5.2L Selec-Trac ~ Rock crawler on the outside, luxo-cruiser on the inside 3.5" IRO lift // 31" Cooper STT's // D44a Aussie Locker // NP242 swap // KOR Tow Shackles '08 Kawasaki Ninja 250R ~ Daily Driver, 50 mpg Speed Demon #27. Shirts get dirty. Underwear gets dirty. Pants? Pants never get dirty, and you can wear them forever. |
#60 |
It all depends on the donor tcase, what year it came from, what tranny it is off of, what phase of the moon was the vehicle built under, etc..
I did a 249-231 swap, and got lucky. My input length matched, my output housing matched. I had to change nothing besides the tcase itself. Existing linkage and all worked out. Seems like you'll just never know for sure till you have the tcases sitting side by side.
DD: 98 ZJ Laredo 5.2, all stock Wheeler/Beater: 93 ZJ Laredo 4.0, AW4, 231 conversion from 249 3" coil lift, JKS Adjustable Track Bar, JKS Quicker Discos, KOR lwr rad supt, Brush guard Colorado Jeep Club Member 242 (4.0L) |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
