#31 | ||
You are correct sir....Hahaaha... Fullsize blazer with 36's stuck and dead in the mud OWNZ a 242... I did get him all the way out though... (2WD was still working... )
Just another soccer moms Grocery getter.... [Url]http://www.jeepforum.com/gallery/files//8/5/6/5/hatt034.jpg[/url] |
#32 | |
If I were to pick up the later parts at a junk yard from a newer donor truck, would they be a direct fit in place of my earlier setup?
'98 Grand Cherokee Limited, 5.9L, daily driver. '98 Grand Cherokee Limited, 5.9L, $650 project. '93 Grand Voyager wheelchair van, 3.0L, chick magnet. '90 Trans Am GTA, 5.0L/700R4. '98 Oldsmobile LSS, 3.8L. |
#33 | |
#34 | |
GSMW!
HTH
-Tim GS-MW 2009 INFO KD8EBC '94 ZJ 5.2 LTD Project TORTOISE Build-up thread JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick |
#35 |
Retired back to Bowties
Novak conversions makes a nice adapter to make the shifter more solid.
Woody 1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch. |
#36 |
Well, my VC finally broke and I swapped in a 23-spline 242 from a 91 XJ LTD. Everything went well except I think I made a mistake in assumptions. The 242 had a short input shaft on it and the ZJ's 249 had a long input shaft. I probably should have swapped them over but didn't and now have a leaking trans output seal or something.
Will the fact that a short input shaft was mated to the trans cause a leak from the output seal? (I am grateful even my limited mechanical expertise allowed me to complete a swap like this, all thanks to the many people who have written about it with pictures!)
1998 ZJ LTD - 5.2L |
#37 |
Ok im running into some problem with my 249 to 242 swap. I have a 97 limited with a shot VC. Went to the junk yard and picked me up a 242 out of a 97zj $400.
Removed the 249 and to my surprise they both have the same length for the input shaft. put the 242 case on the tranny and with my luck the shifter linkage would not work. Have any of u guys run into this problem? Im guessing that I have to get the linkage from the donor jeep. Haveing a hell o f a time takeing the VIC cover to swap the wires
Tater BLACK 97 ZJ 4.0L-42re-242-DANA 30/35 (3.73)
MODS) 2in lift-30x9.5x15 BFG A/T-15x8 Pacer Wheels-K&N Intake-1in TB Spacer-40Series Flowmaster-Hi-Flow Cat-JKS Trackbar-Sliderz-BDS adj CA-BDS SS-Cobra19 ULTRA III-FireStick4FT-PA Horn-Hella500 DL-Roof Rack-TC Skid-Gastank Skid Last edited by 97zjjeeper; 01-21-2007 at 12:08 PM.. |
#38 | |
My FSM says part number 5207 8116 is what you need. |
#39 |
well ok anticrombie i will have to look for that.
well got VIC out and cant find a different plugin for it for the 242 setings sorry for the BIG PICS![]() ![]() ![]()
MODS) 2in lift-30x9.5x15 BFG A/T-15x8 Pacer Wheels-K&N Intake-1in TB Spacer-40Series Flowmaster-Hi-Flow Cat-JKS Trackbar-Sliderz-BDS adj CA-BDS SS-Cobra19 ULTRA III-FireStick4FT-PA Horn-Hella500 DL-Roof Rack-TC Skid-Gastank Skid |
#40 |
Looking for a red wire its wont be one of the wires on the vic connector. Its behind the vic..
Not a very close up picture, but you can see the red connector back there. They may have changed the color in later years. ![]()
- Joe - '95 Jeep Grand Cherokee Laredo I6 4.0L 242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs Moog Cargo Control Springs Magnaflow Converter - Dynomax Muffler 235/75/15 AT Uniroyal Liberator Tires |
#41 |
ok i found the wires u were talking about there are red and black i unpluget the red and pluged the black in and they only lite up the 2wd 4wpt and 4wft. and 4wlow dose not lite up.
are there 2 plug ins? when i put her into 4wlow part time lites up.
MODS) 2in lift-30x9.5x15 BFG A/T-15x8 Pacer Wheels-K&N Intake-1in TB Spacer-40Series Flowmaster-Hi-Flow Cat-JKS Trackbar-Sliderz-BDS adj CA-BDS SS-Cobra19 ULTRA III-FireStick4FT-PA Horn-Hella500 DL-Roof Rack-TC Skid-Gastank Skid Last edited by 97zjjeeper; 01-21-2007 at 04:08 PM.. |
#42 |
I had a similar problem after my swap, with the correct vic info showing wrong. but after a while I got a SERVICE 4WD SWITCH. Then a few days after that it started working correctly. so I think the switch may have been sticking from the time spent in the wrecking yard. you may have a similar problem.
There is just the two plugins. the ones that are pluged in. unplug them, plug in the others. they do not all get pluged in. its one(red) or the other(black). Edit: I read you thread again; I dont think the lo is supossed to light up with the 242.
2003 Jeep Rubicon
#43 |
OK thats what i thought also just need time to work in maybe.
anticrombie -Joe- kdt1970 thanks for your help and Monday i will see if i can get this swap wrapped before o go to work i will keep up up to date with the progress.
#44 |
PUMAZJ,
Thats what my 242 looks like too. I was pretty curious as to why some of them have the different style tail housing. The design in the pic looks like it woudl be better since you coudl pull your driveshaft without losing fluid. It does however have a different seal for the output shaft, so if you go to napa and ask for the seal for a 242 they might give oyu the wrong one if you ahve that different style tail housing. |
#45 |
so is this thing basicly plug and play for a limited with the quadradrive? and yes i dont know crap about the WJs but im trying to help a friend (read trying to convince a friends dad to fix the jeep and give it to the friend so i have another wheelin buddy)
stuff |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
