Quantcast 247 transfer case bolt torque question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 247 transfer case bolt torque question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 03-08-2009, 06:23 PM   #1
mattman0o0o
2005 WK
Hey all, I have a leak comming out of my 247 transfer case. I'm pretty sure I've narrowed it down to the front output shaft oil seal, that or from what I've read in other posts potentially a rubber seal behind the nut that holds the yoke on. Somewhere around the front yoke though.
The question I have is, does any one know what torque the nut that holds the front output yoke on is supposed to be torqued to, my shop manual does not have any specifics on bolt torques or even disassembling the T-case.
Any info on this oil seal replacement procedure would be helpful if someone has done it before.
Thanks in advance.
mattman0o0o is offline   Reply With Quote
Glock Forum
