247 -> 242HD swap "Yoke question" - JeepForum.com
post #1 of 5 Old 04-18-2008, 08:06 AM Thread Starter
UUJ1
So I need to switch out the front output CV yoke on my 247 and put it on the 242 (has U-joint yoke obviously), do I need to worry about the same things like backlash and all that for doing this or can I just swap it over and tighten 'er down?
I was talking with my dad and he was asking me when we were going to do the swap, and brought this up. I didn't think you had to worry about backlash like what's associated with swapping out a yoke on a Diff, am I right?
'99 4.7 WJ,
3" IRO/Addco rear sway bar/ 31x10.5 Pro Comp XMT's(Yes, I changed my mind and decided on these)/ Pro Comp Mountain Crawler soft 8's 15x7 w/3.75" BS
242 in my garage... still
UUJ1 is offline
post #2 of 5 Old 04-18-2008, 08:22 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Nope on the TC it just needs to be tightened down properly...I don't have the torque specs for you - I think I just bubba tightened mine down to like 125 ft-lbs
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 5 Old 04-18-2008, 10:23 AM Thread Starter
UUJ1
That's what I thought... Thanks Arlo. Hopefully I'll be doing the swap in the next couple of weeks. Too busy with work right now, it'll sure be nice to have 4-Hi !
'99 4.7 WJ,
UUJ1 is offline
post #4 of 5 Old 04-18-2008, 01:52 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Ryan is right on the money.
I'd be interested in a pic of your 242HD yoke, specifically the female splined portion that faces the case. Just wondering if it has the same un-splined section for the first ~3/8" like that of the 247 yoke.
Good luck with the swap. Grab an 8mm wratcheting wrench... it is much faster and easier to work with than a wratchet+socket due to clearance.
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #5 of 5 Old 04-18-2008, 03:18 PM Thread Starter
UUJ1
I'll try to get pics up when I do it. Not sure when it's going to get done though...
'99 4.7 WJ,
UUJ1 is offline
247-->242HD Swap, where to buy wiring? bill38jeep ZJ Grand Cherokee Forum 15 01-17-2010 01:10 PM
242HD SYE (Slip Yoke Eliminator) now available from Tom Woods!! theksmith ZJ Grand Cherokee Forum 3 10-20-2009 05:41 PM
247-242HD swap help reconbyfire ZJ Grand Cherokee Forum 6 02-13-2009 02:27 PM
IRO trussed, locked 44's + 6.5" and 242hd installed Dayzz ZJ Grand Cherokee Forum 20 12-02-2008 12:06 PM
4" lift, slip yoke elimanator question... kujo666666 ZJ Grand Cherokee Forum 8 09-13-2006 03:05 PM
